how big of a cam can i go with stock converter - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-07-2011, 09:45 PM
Hi I have a roller. 350 I wanna kno how big of a.cam I can go with a stock converter its a 95 4dr s10 blazer its got 295 50 15 rear tires with 373 gears its got a 700r4 out of a 87 full size blazer I got headers edelbrock performer intake holley 3310 carb I wanna go a choppy as possable
Old 09-08-2011, 12:04 AM
The thumper
Old 09-08-2011, 09:07 AM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Originally Posted by 70chevelless
The thumper
Really? How did you arrive at that determination?
Old 09-08-2011, 12:34 PM
Irelands child's Avatar
You can put any camshaft in that you want to - but you will kill any performance gains with the 15-1800 RPM converter, plus 3.73 gears with 27-28 inch tall tires
Irelands child
Old 09-08-2011, 01:06 PM
cool rockin daddy's Avatar
The thumper
Stupidest reply ever. OP, you have to have a cam that the powerband matches the converter. The two go hand in hand and the relationship cannot be ignored. Call any cam company or converter company and LISTEN to what they say.
Old 09-08-2011, 04:13 PM
I know it depends on the engine, cam, and converter but I have the stock converter in my F100, with a modified 302 (unknown cam; 14" vacuum). It pulls the idle down from about 800 to right under 500 rpm on the tach. Performance is pretty crappy off the line.
Do yourself a favor and replace the converter even if you are getting a cam that *should* work with the stock converter.
Old 09-09-2011, 01:19 AM
Ok I will be stupid he wants a cam that sounds and there is more then one thumper. The stock converter he has should give 20 to 22. Don't hate and what did you recomend.
Old 09-09-2011, 03:45 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You need to realize that the "choppiness" you desire comes from the engine's inefficiency at low RPM, and it's an undesirable trait of a performance cam once the overlap/duration exceeds a certain point.
Unless this is a w/e toy or race only, instead of trying to build the engine into a radical sounding, but turd-like performing poser, build it to be efficient while still making good power in the RPM range you find yourself using the vehicle in the most. This will mean a cam w/more lift but w/o excessive duration and overlap. This will compliment the parts you already have and will make driving it a pleasure as opposed to a chore.
If you still insist on "choppy", lose the stock torque converter! Plan on some deep rear gears, more like 4.11-4.56, else OD will be non usable. Depending on what diff you have, this may need swapping out for a stronger unit and needs to be a limited slip as well.
Old 09-09-2011, 03:59 AM
I won't say anything I'm out.
Old 09-09-2011, 07:08 AM
DoubleVision's Avatar
We used a Comp Cams Magnum hydraulic roller that`s the smallest of the line. It`s got .215 duration @.050 and .500 lift, it hits a nice lick at idle and still has good low end street manners and works with stock converters.
Unless you step up the rest of the engine this is about as choppy as you can go. When the cam goes up, the compression, head flow, exhaust flow all has to go up with it. If you stick a big cam in a stock runner your not going to like the results as it`ll be a turd. As far as the "thumper" reply that was mentioned you can ignore it. Thumpers are fad cams designed for those who don`t know how to make a standard high performance cam lope at idle.
If it`s tuned correctly, a high performance cam lopes just fine at idle.
When it comes to the thumper line they are what I call "bark and no bite"
Many have already found out they are very poor performance cams but they sound mean.
Did I buy a stall converter or a stock one in a TCI box? heathj1 Transmission - Rearend 5 07-04-2009 05:50 AM
B&M Torkmaster 2400 rpm stall converter vs. stock torque converter??? zbhover Transmission - Rearend 2 11-02-2008 07:52 PM
Cam too big for stock converter? or ? FASTCHEVY Engine 10 03-09-2006 05:55 PM
Stock Converter SBC-S-15 Transmission - Rearend 1 06-06-2004 05:52 PM
what's the largest cam i can run with a stock converter? COCHEV Engine 24 11-29-2002 04:54 PM
