I got an 85 too, with 275/60/15's out back on 8" wide rims.
The tires look really cool, they JUST tuck under the quarters and DO rub a little over big bumps with the stock springs, so i cut the fender lips off to keep the tires from getting shredded. There's quite a bit of clearance between the tire and the frame though. I'm not sure of the exact offset or backspace specs, but the wheels are Eagle Alloys baja style (8-hole, polished alum.) Hope that helps. In any case, I would advise against 15 inch wheels and vouch for 17's. I know that 15's look cooler (at least I think so), but you can't get good BIG grippy summer tires for 15 inch wheels, unless you want the NO-season kind, I'm running dean stingers right now and they hold pavement as well as greasy ice. |
thanks, i was hoping they would fit. with the 255's i have on it there's about 1/2" of clearance from the frame. i might have to use 7/16 or 1/2" wheels spacers to get the 275's under it. if i do the i will try to find 1/2" longer lug nut studs (if they make them) to keep the wheels on. do you have a picture of your monte? i'm like you, i think 15" wheels look way better than 17's (on anything).
