Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How to bleed brakes?
Old 09-09-2005, 01:48 PM
Rob Keller's Avatar
Rob Keller Rob Keller is offline
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
thanks dave see it always good to give everything you got i didnt know that about the check valves .
how much are they?
would they work with the mighty vac ?
just to be tidy.
yes you can bleed the brakes with the master cover off but you have to pump really ,really slow or it comes flying out
if you gravity bleed leave the cover off fur sur.
SR66
"SlowRide66"
"Illegitimis non carborundum"
Crankshaft Coalition Master List of Hotrodding Forums
