Yes i never try to prime up to the tape line because you will see the color of your primer at tape line. I try to blend color at the lower edge of the reverse curve or in the middle of it. Then when you clear don't use any more than necessary and stay away from the tape line as much as possible until your last coat go right up to it. Then after it is good and dry sand lightly very lightly over the tape line more of a scuff than a sand then lightly hit with a buffer.
