How to blend Ford E9 tinted clear? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-17-2007, 08:42 AM
ChrisMiddleron's Avatar
Hi
I have a 01 Mustang GT I need to shoot the rear bumper and Quarter panel on. I am using the trunk and door as blend panels. I can blend regular BC/CC but ford E9 is a tinted clear like a candy. How would I go about blending E9? Should I just toss the copper color base as usual and then toss the tinted clear back or do you guys have some tricks to spraying this stuff?
Any help would be appreciated im going to be spraying tomorrow.
Thanks,
Chris
Old 04-18-2007, 12:49 AM
Rag top bird's Avatar
Hot rods are still the king
no you need to tape off the panal to be blended then do you cooper base get it covered then unmask your blend panal then blend the cooper color on your blend panal then blend you candy the same way you did the cooper color then you may have blend out say 8" past that with you candy
Old 04-18-2007, 09:06 AM
Ok ill be shooting it thursday so we will so how it comes out.
Thanks,
Chris
Old 04-18-2007, 09:30 AM
Believe it or not, just use your common sense, it is that easy. Blend the base out and then apply the candy in the same area. If you blend out past the base too far you are going to darken the surounding area.
The more mid coat candy clear you apply the darker it will be right? Well, if you have three coats of candy over your base to match the three coats of candy on the car and then you have six coats of candy just past your base blend then you will have a darker area where those six coats are, it is that simple.
Make yourself a "let down panel" this is IMPARATIVE to match the color. Spray your base out on a spray out card. Then mask off a mask off all but about one forth of the card and spray a coat of the mid coat candy. Then move the masking paper back to expose another fourth of the card leaving the last half of the card still covered. Spray another coat of the candy. This will give you two coats on the first area sprayed and one on the second. Now move the masking paper back to expose another quarter, spray another coat. This will give you three coats on the first area, two on the second and one on the last one. Now pull off all the masking paper of the last quarter and shoot another coat. You will have four on the first area, three on the second, two on the third and one on the last. This is a "let down" card. You will see four totally different colors. You then use this to match the car. See how many coats most closely matches the paint on the car. Check it in GOOD sun light, not in the garage.
You now know how many coats of candy you need to spray over your base to achieve the color. You will also see how adding more candy over your existing paint will darken it. So keep the candy blended out on where the base was blended out and you will maintain the same color.
Old 04-18-2007, 04:12 PM
Last journal entry: metal finish
The base of this color is maroon as well(atleast with basf) its one of the easier tri-coats to blend. Just blend it out how u would do regular base. blend the base.. then blend the mid-coat past it.
M.S. requested joke thread hotrodit Off-Topic 187 08-31-2014 07:14 AM
46 ford p/u model # ( WRONG ) ? biglee550 Suspension - Brakes - Steering 19 03-17-2008 09:45 PM
Wanna Talk Cars "Fords" 66Falcon Hotrodders' Lounge 17 10-01-2005 06:29 AM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 10:20 AM
Ford Race Engine BarbWire Engine 7 10-18-2002 12:38 PM
