How to on Body Off Build? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-07-2006, 06:50 PM
joeford's Avatar
36 Dream
I'm in process of removing the body from a 36 Ford Coupe in anticipation of placing it on a TCI frame that I've got. I've removed every frame bolt and floor pan bolt that I can find, yet can not see that by prying the body is ready to come up. I don't want to call my buddies in for the actual lift until I know that everything is ready.
The body is stripped of everything but the spare tire, which will come off next. I'd like to keep the doors in place as this I believe will help maintain rigidity and lessen the risk of the body torqueing upon removal.
When I pry the body from the frame at the firewall on either side, I do get some movement which is a possitive sign, but only 1/4 inch or so...Any attempt to get the body lifting from the rear has been futile.
Ideas from anyone with experience in pulling old bodies from frames, would be much appreciated. It really seems that I am at a stoping point for the moment. This is my first time, so it is entirely possible I'm overlooking the obvious...
Desperate....
Old 05-08-2006, 09:29 AM
Wiki Edits: 49
Before tackling any project like that you need a body manual for the car. Almost any decent sized swap meet will have someone selling them. A good body manual will show you where all the bolts are. You'd be surprised where they can hide body bolts on those old things.
Old 05-08-2006, 04:59 PM
Last journal entry: It's getting there
1936 Chevy
Try www.gregsonline.com they have shop manuals for the '36 for $20.00. I used one for my '41. saved a bunch of time.
Old 05-09-2006, 07:29 PM
Most bolts are installed vertical, but there are a few that come in form the side. The sneaky ones are the two bolts that hold the sill plates on and a couple that are in the side pockets on the frame just in front of the rear wheels (right where the frame rails start to hump up to clear the rear axle. The rear bumper bracket mounting bolts also go through the tail pan of the body and the frame. There are also vertical bolts that lock the floor pan to the X members. I do not remember if any of the woooden strengthening strips are bolted to the frame or not.
If your floor pan is intact, then you are not gaining any thing by keeping the doors on. If they are rusted out badly, I would still remove the doors and tack weld in an X brace from 1"X 1/8 angle iron or square tubing for rigidity.
If you are going to have Buds come by for the big lift, i suggest you raise the front end first and slide a long 2X4 under it and do the same on the back. Prepare the blocks, saw horses or dolly to recieve the body and then one Bud opn each end of the 2X4s can easily move the car to it's resting place. My bud and I have removed several bodies by our selves, using rope bridles and 2X4s and an engine hoist. We pass the 2Xs through the door/window openings, tack a board from one to the other to keep them from sliding to gether and loop ropes from the cherry picker hook to the 2X ends and pick it right up. One of us mans the hoist and the other stabalizes the body.
Trees
28 body doesn't seem to fit the frame oldguy829 Body - Exterior 17 11-28-2007 02:39 PM
Body mount question mrmagoo187 Body - Exterior 5 08-10-2005 10:51 PM
Body Caulking with nice finish. rrmccabe Body - Exterior 7 07-19-2005 08:46 PM
Jeep 2.5L throttle body to 4L throttle body. Parisienne66 Engine 2 07-10-2005 08:35 PM
body panel alignment gmonkey Body - Exterior 5 09-01-2003 06:50 PM
