how bout engine swap? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-19-2002, 02:21 PM
Post how bout engine swap?
have 40 plymouth coupe all original FLH6 3 speed
have 68 chevelle chasis and drive train with 327/350 10 bolt.
will my 40 suspension handle the swap without major modifying?
Old 04-22-2002, 06:20 AM
Wiki Edits: 49
Post
It will probably be OK but you won't like the ride or handling. At a minimum you need to rebuild the suspension, replace the springs and as a matter of safety consider replacing the front brakes. The stock rear end won't handle a V8 so you'll have to change that anyway, but you'll also have to change or update your master cylinder. Always think safety first.
Good luck.
[ April 22, 2002: Message edited by: Centerline ]</p>
Old 04-22-2002, 05:19 PM
New Member
Post
Just to tell you what I have done. I am running a 318 plymouth in my 47 Desoto, with stock suspension and rear end. Ran all last summer without a problem. I am updating the brakes though to disc in front using the stock master cylinder or possibly going to a dual cylinder to be on the safe side. I probably will put in a different rear end just to gain the emergency brake but the old one seemed to work fine for me last year
Old 04-22-2002, 09:51 PM
New Member
Talking
You should keep iyt all Mopar i would opt for a 340 or maybe a 360 outta a dakota R/T and you should pirate the suspension outta a wrecked one and use it.
But thats my opinion do what makes u happy.
Newport
Old 04-23-2002, 05:52 PM
Post
Hi I have a 1939 desoto 350 V8 350 auto & 10 bolt
chev.rear end.I rebuilt the front end droped the front end (fat man ) also added disc brakes also
fat man 3" droped springs (butch rod shop)It handels very good thats 3 years ago 20,000 miles
Just finished puting in power rack an 60+ stearing box not an good thing? If you want to know how or what worked for me "E" mail me @
philsuezq@aol,com and I will explain.....Phil
Old 04-25-2002, 12:39 AM
Cool
No. I'm working on a 41 Dodge coupe right now, a Nova subframe is splice welded into the front and the wheeltrack looks right. A chevelle is a wider car with a wider wheeltrack, sounds like a misfit.
Old 11-02-2003, 11:05 PM
Babyhemi's Avatar
40 Plymouth
use a narrowed B-body mopar or mII for the front & a 73 B-body rear it bolts right in
