how to build a 327 for my 63 c20 fleet side - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-31-2010, 12:19 AM
I just picked up my 63 C20 fleet side it has a 327. I absolutely know nothing about what I would need to buy in order to make it run half way between a stump puller and a street machine. I know my C20 is a very heavy truck and am looking to get a bigger engine latter down the road. I would also like to put this 327 in a car some where down the road so would like to build it right. I have 1,400 to spend on it now and more latter if need be. looking for your help.
Old 08-31-2010, 05:58 AM
There are many ways to go about it. For the truck you'll want something that gives it more low end grunt for pulling power. Not to mention that truck weighs quite a bit.
If you don't know much about engines, I would purchase a book on rebuilding...There are tons out there and a good place to start.
http://www.amazon.com/How-Rebuild-Yo.../dp/1557880298
PS-maybe look to something like the Edelbrock Performer or any type of RV/Truck Cam and dual plane intake.
Old 08-31-2010, 07:50 AM
My dad and I built a nice 327 for his 55 chevy 210/4spd. Sm Journal 327 +.030. Reconditioned rods, stock steel crank, refurbished over the counter fuelie heads w. 2.02/1.60 valves, KB hypereutectic pistons. compression is mid to low 9s, car runs on 89 octane. Edelbrock Performer (non RPM - dont ask me why) AirGap, Edelbrock 1406 carb w. elec choke and a comp cams 262H. Pertronix Ignitor II ignition conversion and coil.
Plenty of bottom end, has a nice idle through the 2.5" exhaust, ported rams horns, LONG cherry bombs (burnt out now) and turn outs before the rear axle...GREAT street rod motor for him.
Old 08-31-2010, 08:44 AM
You can't build a good 327 for that little. You need about twice that. I would look into buting a running vortec 350 do a intak/carb/dizzy swap and install a used zz4 cam. It'll total around 1500.
Old 08-31-2010, 12:02 PM
First thing you need to know is that a 327 is a strong mid-range configuration. (2500-6000 rpm's) That means that if you want it too make any bottom end torque at all below 3000 RPMs then you will need to focus on that like a laser. If you already have a stock quadrajet intake that is a good start for making torque. Stay away from single plane intake manifolds. For a good street 327 I also prefer a regular performer intake to the RPM for the reason given above. The next thing you'll need is a good set of heads. I went with a ported set of fuelie heads, Vortecs would be even better. What heads do you have now? Whatever you do here, if you go with aftermarket heads then DO NOT GET HEADS WITH HUGE INTAKE RUNNERS! Factory fuelie heads have all the flow a street 327 will ever need, and once again their small (by todays standards) runners are a plus for making torque with small cubes. If you want something for the strip that is a whole different ballgame.
The cam I went with is just a little Elgin E1029p. .050 durration 214/.443 lift. $55.00 from Competition products and it is VERY similar to the 350 horse cam. Not quite as much duration but the dynamic compression should be better, more bottom end torque.. Yet hitting 6500 Rpm's should be a walk in the park. I will also be using high ratio 1.6 rockers on the intake which will bump the lift up to about .470.
An excellent performance piece for a 327 would be a hydraulic roller cam because that way you could maximize lift without too much durration. But finding one with the right specs for street use in a 327 could prove challenging as the market is mostly focused on 350 and bigger motors.
These are quite different from building something with a longer stroke. If you went with a cam that is suitable for a stroker or a 400 you would end up with a guttless pig until it hit 4-5000 RPM's. So take extra care when picking your intake and cam, and give 'er a good set of heads. That is my advice, and otherwise they go like he!!.. Oh, and carburetors on the smallish side (600-700 cfm's) are quite suitable.
Have fun..
Best way to build 327?? chevelle327 Hotrodding Basics 4 01-10-2013 03:17 AM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
build a 302 or 327 dadsgp Engine 2 08-25-2004 11:18 AM
327 build amish Engine 5 05-18-2003 10:06 AM
327 build up ? tjk2000us2000 Engine 7 11-09-2002 10:08 PM
