how to build 383 chev engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-08-2003, 06:31 PM
Hello, I'm new to this so please bear with me! I have a engine that i am tring to put together from scratch it is a 383 small block that i'm going to put in to a 1972 chev pick-up I have tried reading all the other messages and have not found what i am looking for. I have tried buying the different books and still nothing. So if anyone knows how to build a 383 chev engine it would help me a great deal. thanks Alan
Old 07-08-2003, 06:52 PM
V8 S-10's Avatar
v8s10.org
http://www.chevymania.com/383.htm
Old 07-09-2003, 12:17 AM
Sandflea427SS's Avatar
Anything with a throttle
Howdy...welcome to the site...Do a search on the archives here at hotrodders.com....There should be days and days of reading....
If not....contact me and I'll let you know what I use for the 383 build up....
Old 07-10-2003, 12:42 AM
To sum it up kinda short -- a 383 is a 350 bored .030 with a 3.75" crank (a crank with the same stroke as a 400 small block). A stock 350 has a 4" bore (4.000) and 3.48" stroke, while a 400 has a 4.125" bore; a 383 has a bore of 4.030 and stroke of 3.75". You can build any variation of strokers by changing the bore diameter.
You need a 350 block to start off with. You should take the block to a machine shop and have them dip it, machine it (make sure to tell them you plan to make a stroker out of it so they can machine the crank journals) , and install new cam bearings and freeze plugs. Your best bet for the crank would be to order a 383 rotating assembly (crank, pistons, and rods) from your machine shop, jegs, or anywhere else. You can use a 400 Crank, but it will need to be machined for the 350 block. Next you need to choose the internals, heads, and finally your fuel delivery, and exhaust setup. That's pretty much it.. there's a lot more to it but that's the basics. Good luck on your stroker!
Old 05-20-2007, 10:24 AM
grumpyvette's Avatar
retired engineer /corvette rac
http://www.chevytalk.org/fusionbb/sh...hp?tid/131229/
this has decent info you can use
