Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - how to build 383/questions
Old 10-01-2012, 06:50 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by smallblock383 View Post
i was thinking about building a 383sbc 400 crank with 400 rods and standard 350 pistons, this will give me a cheap 383 or 372 sbc the old school way. but the ? i have it what cylinders i have to clear and shave my friend told me i can make clearance for rods my self with a little hand grinder so rods don't hit block
this the crank
Eagle Specialty Products 103503750 - Eagle Cast Steel Crankshafts - Overview - SummitRacing.com
with these rods
Pro Comp SBC Chevy 5.7" I-Beam 350 383 400 Connecting Rods - 41103 | eBay
Stock 400 SBC rods are 5.56" long. I do recall seeing a crank for the 5.56" rods but I don't recall who made it and I wouldn't recommend using the 400 rods anyway.
As for clearance, rods #2 and #6 are most likely to hit the cam but all of them need to be checked for clearance. You probably will not have any real clearance probs. between the crank and block at 3.75" stroke. Just check to see that you have 0.040"-0.060" clearance between the pan rails and bottoms of the bores and the reciprocating assembly.
