Build hot rod how-to articles
100+ user-created articles:
'37-'57 Buick Olds Pontiac suspension upgrade, Body-exterior tips, Bulletproof cooling system, Buying a trailer, Cheapo paint job, Cold air intakes, Cylinder head choice, Determining TDC, E85, Epoxy primer, First paint job, Free T-Bucket plans, GM transmissions, Head gasket, Header design, Health and safety, How to find an electrical drain, How to title a hot rod, How to identify a Ford V8, Make a fiberglass fan shroud, Media blasting, Patching a body panel, Pitted rust, Pre-1980 VIN decoding, Removing stuck fasteners, Rewiring a vehicle, Waterproof panelboard, Why not to use a SBC engine, and many more...
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 03-04-2007, 09:12 AM
propaine rockcrawler propaine rockcrawler is offline
how to build 454 to run propane with 600+HP?
hey guys I need help .. I have a stock 454 and need it to run propane only,with a full dry sump,need lots of torque! It has to run at any angle even upsidedown! its for a competitive rockcrawler and most of all it has to be cheep!!!! no $$ build so what compression dose propane need to run hard and what can I do to the motor to get more compression? I have a www.gotpropane.com system for a 454, and I have a 4stage dry sump system with 4gal. tank, and a stock 454,,, I have a machine shop in my business called www.usa6x6.com. so I can do some machine work for free .. but don't no engines! should I put a stoker kit?
any new parts I buy will come from ebay,, some one please help me!!! you guys are smart please list all I need to build this 454 rockcrwler motor .. thanks Heath..
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "how to build 454 to run propane with 600+HP?"
Build for Hp or Torque? Venturat Engine 76 09-23-2008 09:22 AM
bbc 454 maximum power engine build up rynophilia Engine 6 07-08-2003 02:07 PM
What is the best way to build a 454 neil madsen Engine 4 11-15-2002 01:43 PM
Whats the best way to build a "under the hood" 454???? neil madsen Engine 3 10-31-2002 06:02 PM
Want to build 500 horse chev 454 79monte Engine 6 05-29-2002 08:20 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
