Demon carburetor Get parts for cheap, all for a good cause.
Parts auctions to protect free speech online.
Click here for details.
Parts currently up for auction: Rat rod chassis parts, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Garage - Tools
  #1
Old 12-23-2005, 02:07 PM
Jon's Avatar
Jon Jon is offline
Administrator
 Jon's barnstar
Wiki Edits: 3,982
How to Build a Utility Trailer
Just added this to the Garage-Tools Articles category of the Hotrodders Knowledge Base:
How to Build a 5'x10' Utility Trailer.
I needed a trailer to haul around a snowmobile so I decided that I might get*better use out of a general utility trailer instead of a snowmobile trailer.* I checked the local trailer retailers and found that the going rate for a 5' x 10' utility trailer was around $1,300 Cdn.* The trailers weren't very*strong and were made mostly from light angle iron.* Always looking for a good project, I decided to build one instead.
Good webpage, even includes AutoCAD plans. However, I'm sure our guys could do (or already have done) the same project for less money.
Write how-to articles with hundreds of other hotrodders. See 100+ articles, or start a new article.
Interested? Read The 8-sentence guide.
Old 12-24-2005, 06:46 PM
machinestheman machinestheman is offline
re: How to Build a Utility Trailer
ive built dozens of these, rear axle from a front wheel drive station wagon, and some steel tubing or square tubing, wooden decking, and a hitch from napa for like 20 bucks or so and some lights a simple four wire system makes this a two day job
hope youre welding skills are up to parr remember 90 percent of welding is prep work keep it clean good luck
Old 12-24-2005, 07:35 PM
Henry Highrise's Avatar
Henry Highrise Henry Highrise is offline
Moderator
 Henry Highrise's barnstar
Wiki Edits: 4
I built my first trailer when I was 18, I am 60 now and have built dozens of them for myself, friends, neighbors , etc. It is not hard to do. I always put my axle 6 in. behind center of the bed. Thats the bed measurement( not counting the tongue). For a tandem axle I put the center shackle mount 6in. behind bed center. Remember the longer the tongue the easier it will be to back. Good luck.
Old 12-25-2005, 10:54 AM
i just want to say ditto on the axle placement if this is overlooked you could be putting too much weight on the rear of the haul vehicle ive even seen where the load was pulling up on the *** of the tow vehicle and also take into account what you plan to haul on the trailer and where most of the weight will be but for general purpose the henry hirise hit it on the button
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "How to Build a Utility Trailer"
this is a saver.... GM build codes TooMany2count General Rodding Tech 23 11-21-2008 07:27 PM
Anyone build a teardrop trailer? gahi General Rodding Tech 7 03-30-2007 08:26 AM
Engine build ideas Rug Engine 23 12-25-2006 01:39 PM
Car hauler trailer questions (???) M&M CUSTOM Hotrodders' Lounge 25 12-25-2005 08:08 PM
Build a kit car Dutchman General Rodding Tech 9 09-23-2005 04:39 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
