how to calculate engine size with different bore sizes??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-25-2008, 01:37 PM
inquiring_mind2's Avatar
a shade tree mechanic
I was wondering how u would calculate what size an engine is after it has been bored out??? I know bbc Have a 3.75, 4.00 and a 4.25 stroke. When U bore it 30 60 90 or 120 over how do you figure out what size it is???
Old 10-25-2008, 02:33 PM
T-bucket23's Avatar
Wiki Edits: 26
The formula is Pi X the radius squared Time the stroke Xnumber of cylinders
so on a 350 chevy
3.1417 X 4 X 3.48 X8 = 349859
Hope this helps
Chet
Old 10-25-2008, 02:52 PM
ok How do u come up with the first 2 numbers??? I am a little dumb as this???
Old 10-25-2008, 03:28 PM
I assume they are pi and radius squared. Although I tried it for my 318 and it showed up as a 332. But here is a site you can use
http://www.csgnetwork.com/cubicinchdispcalc.html
Old 10-25-2008, 04:15 PM
formula for displacement
(BORE)X(BORE)X(STROKE)X(.7854)X(NUMBER OF CYLINDERS)
EXAMPLE: 4x4 x 3.48 x .7854 x 8= 349.848576 round up 350ci
I've never heard the one using PIE, but it looks like it works... I just find this one a little more simple..
Danny
Old 10-25-2008, 04:18 PM
ok where does the .7854 come from
Old 10-25-2008, 04:33 PM
RippinRon's Avatar
Your right, pie X radius squared X stroke X no. of cylinders.
Old 10-25-2008, 05:17 PM
I dunno, Some guy smarter then me. I just know it works and It's easier for me. If I works I don't question it.
If u got a gonkulator handy you can check it. It will be accurate every time. It came outta one of my books, Prolly David Vizard... I don't think any of us have a need to question him.
just try it.
383ci: bore is 4.030", stroke is 3.75"
406ci: bore 4.155" stroke 3.75"
434ci: bore " " 4.00"
302 : bore 4" stroke 3"
Old 10-25-2008, 05:39 PM
LOL OK thx sounds good to me
Old 10-25-2008, 07:04 PM
tnovot's Avatar
Pi is a mathematical constant - always 3.1417
The second number is the radius squared. The radius of a circle is 1/2 the diameter, in this case, 1/2 the bore. The stock bore of a 350 engine is 4.0 so 1/2 of the stock bore is 2 and 2 squared is 2 times itself or 2x2 which is 4.
Terry
Old 10-25-2008, 07:22 PM
Wiki Edits: 31
Pi is actully 3.141592654.. it does continue, but no calculator can count that high. if you used 3.1417 the displacement would be off a little, it would be more accurate to use 3.14 only.
Old 10-25-2008, 07:34 PM
Cylider volume = pi/4 x bore squared x stroke[list]
Pi/4 =0.7853982
Old 10-25-2008, 08:05 PM
ok thank you very much for all of your help
crate chevy 302? Vancouver Grand Prix Hotrodders' Lounge 106 12-31-2012 04:05 PM
Chev 4.3Liter Bore size.. and chev 305 or 350 bore boneyard Buick Engine 9 08-08-2006 10:55 PM
engine size stairchallenged Engine 3 01-25-2005 08:48 PM
Ford Engine size Rancher Engine 6 11-23-2003 12:45 AM
Ford Engine Sizes bigjoedo Engine 1 01-31-2002 04:05 PM
