How can I build a 454 "POWER" Engine?
I have a 1991 Pace Arrow 37’ motorhome on a P30 Chassis. The engine is a stock 454 rated at 230 HP and about 300-350 Ft Lb Torque. It has the throttle body injection system. Not enough “umph” to pull itself up a good size hill, let alone with my enclosed 22’ Trailer attached (for my Sandrail and Honda Pilot) at about 5,000 to 6,000 Lbs. I also have a serious concern for overheating with the doghouse and low circulation. It has the normal clutch fan and an electric pusher fan, plus a water spray mist system in front of the radiator that I added.
I just bought a 454 Chev Truck Motor to rebuild into a power house for this motorhome. I need to know just what do I need to do for this project. I have only built my Corvair engine for my sandrail, and don’t know much about these engines. I will have a machine shop and a friend help with the engine build, but I like to know just what is going on.
I would like to pick up a book on Big Block engines that will help guide me through this project, but don’t know what is a good one. Any suggestions?
DoubleVision has told me to increase the compression to 9.5:1 and to add an RV cam, such as the comp 268H series, add an Edelbrock performer intake, a K&N air filter, a brass terminal cap, spiral core spark plug wires, headers and a decent exhaust system with crossover pipe to give it more torque. Also Siggy_Freud suggested MSD box. I really appreciate these suggestions.
Since I am going to build the motor, I plan on have the block align bored, vated and everything balanced.
Now what about the crank, rods, pistons, heads and other stuff? Where will I get the bang for the buck?
If I add headers with the stock heads, will I have problems with the spark plugs (servicing)?
If I get heads which should I get? Angle/straight plugs? Oval or Rectangle ports? What CC chambers, What is the optimum Valve size? Cast Iron or Aluminum?
What about the crank for the extra HP and Torque, the Rods anything else? Oh yes what about “stroking” this baby.
And then the pistons. Domed, flat top, etc.
The cam, roller rockers, roller timing, all the other trick things I have heard of but don’t know much about?
Am I going to have problems with the computer? Where is the computer and what does it look like anyway? Any suggestions on Chips?
Oh yes, and after all this information I would like it to pass “emissions”.
Enough challenges? I really appreciate any help you can provide. Thanks Steve
