How can I convert a 7-pin module hei to a 4-pin? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-19-2006, 04:48 PM
I would like to convert my 7-pin module vacuum advance Delco Remy V6 distributor into a 4-pin so I don’t need a computer because I don’t have one. I have a brand new in plastic AC Delco 4-pin module I got for a trade that I would like to use.
4 pin module works like this right?
C – Coil -
B – Coil +
G – Pickup -
W – Pickup +
Base as ground
So can a just wire it like this or do I need to change some things.
The 4-pin module is for a 350V8, will it work with my 4.3V6?
Old 11-19-2006, 04:53 PM
Wiki Edits: 31
you don't convert a 7-4 pin. get the HEI from a carb'd 4.3, it will be 4 pin. 7 pin has full ECU control and no advance, all locked out for computer
Old 11-19-2006, 08:40 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Go Here for the conversion , and kit..
MegaSquirt
Be advised, you will need the module to cap harness, and maybe the magnetic pickup as well (different years had different Ohmic Values) AND you may have phasing problems.
An earlier HEI (pre 80) or Aftermarket may be a cheaper option..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
MSD digital HEI module with rev limiter???? baddbob Engine 2 07-03-2006 02:06 PM
HEI Module w/points lakota Electrical 12 05-12-2006 03:32 PM
Anybody running an MSD HEI module? baddbob Engine 10 07-15-2005 09:56 AM
Quick question on MSD HEI module Jmark Engine 1 06-17-2005 02:43 PM
HEI Module horvath Engine 8 09-09-2003 05:57 AM
