How can I de-chrome my grill - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-26-2004, 11:53 PM
my grill only has 1/2 the chrome left on it, and I'd rather paint it the body color instead. Can I de-chrome it myself, or is there a primer I can use over chrome.
If I have to take it in is there any type of shop that specializes in this.
Thanks
Old 11-27-2004, 12:07 AM
AngliaBob's Avatar
It just takes time and money
Last journal entry: Specifications
28 Essex,
If the chrome is not peeling, or stripped off, in spots...
You can give it a light sand blasting, apply a sealer, and paint the body color of choice.
AngliaBob
Old 11-27-2004, 12:13 AM
Oh I'm sorry I should have said, it's flacking off in places
I haven't tried blasting it yet, does the sandblaster sometimes peal the old chrome off?
A friend of mine tried sandblasting newer chrome, and I'm not sure if he used the wrong primer, but the paint didn't stick
Old 11-27-2004, 12:23 AM
AngliaBob's Avatar
Essex,
My experience has been...If the chrome has peeled or flaked.
sandblasting very close, gets rid of the problematic areas. I have always tryed to get the chome stripped, to the point were I can see good adhesion. The uneven areas can be treated like any other body panel. (IE: filler,poly,etc)
Old 11-27-2004, 12:27 AM
Thanks for the tips, and I'll give it a try.
Old 11-27-2004, 12:35 AM
AngliaBob's Avatar
Essex,
If you can't get the sandblasting to do a good enough job, on the edges, use a 36 grit and then an 80 grit on a grinder or d/a.
AngliaBob
Old 11-27-2004, 09:00 AM
You are going to want to use a good etch or epoxy primer to stick to it. Just any old primer or sealer isn't going to do.
Old 11-27-2004, 04:19 PM
Old enough to know better
I've sandblasted an almost new chrome bumper, sprayed with epoxy primer (PPG DPLF) and topcoated with good luck. It's on a big 4X4 and has gotten a couple of dents in it without disasterous results. I believe the secret is that you want the entire surface dull, no shine left anywhere. That gives the paint enpogh little pits that it sticks well.
Old 11-28-2004, 04:19 AM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
Find a pace that chromes and they can strip it clean. Under the chrome you have copper and nickel and rust. That is why the chrome is coming off. The rust or contaminated areas are letting everything else come loose.
Kevin
Old 02-01-2012, 12:14 PM
painted over chromed parts
Like Kevin said take to chrome shop to have it the chrome stripped off. Then have the surface LIGHTLY sandblasted to etch the surface. To prime the part, use the YELLOW primer thats used for aluminum and non steel. Its an special etching primer, you can buy in a spray bomb. Then prime and prepare over it with regular lacquer or high build primers.
mike
