how can i get traction - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-29-2005, 01:24 PM
joseph w.'s Avatar
im the guy you lost to.
hey guys, i have a 1986 chevrolet c-10. its powered by a 305 with a crane powermax cam kit with 208*/214* duration, edelbrock performer intake, and performer 750cfm carb. i have a b&m holeshot 1,900-2,000 rpm coverter, a built 350th with stage 3 powerbands, all steel cluthces, solid servo(spins through 1 and 2, barks 3rd gear). i kept the stock gears which i believe are 3:72s. this truck produces a tremendous amount of torque throughout the rpm range and with the truck being lwb, it has very little traction. i have broken transmission crossmember bolts with this transmission, and 2 sets of traction bars. nothing seems to be able to withstand the hard shifting transmission. with this infornmation, can someone please tell me how i can get my truck to hook up? its a daily driver also. i am rather pleased with the performance of the truck, but i just gotta stop breaking traction. thanks in advance guys, im just dont know what to do.
Old 01-29-2005, 01:33 PM
Duh!!! Lighten up the right foot.
Sure would like to get my hands on all that awesome power from a 305!!
Trees
Old 01-29-2005, 01:36 PM
BOBCRMAN@aol.com's Avatar
That, or put a VW sedan in the bed..
Old 01-29-2005, 01:41 PM
joseph w.'s Avatar
letting out is not an option.lol... would adding weight to the rear help? i thihk the fact that its so long is the reason it spins so much, the "awesome power" is just under 300 horses. not really all that much power. got another suggestion?
Old 01-29-2005, 01:59 PM
RCastle's Avatar
Come Home Safe Soldier
Last journal entry: Headers
Make sure all your motor mounts are tigh,transmission crossmember and monunt are tight.You can install anti hop bars on the lower edge of the springs,Are the spring shackles and bushings wore out? That seems like it may be a big possibility,as there are plenty of those trucks out there with Large power 350 and even some big blocks that are not having troubles such as yours. I would inspect your springs and shackles,replace the bushings and maku sure the u-bolts are tight and have not slipped,
Mighty Mouse S-10's Avatar
Cleverly disguised as grownup
Last journal entry: Hollman & Moody
Posi, solft tires, 4 link, fuel cell and battery in truck bed. What if any of these have you tried?
Old 01-29-2005, 02:07 PM
joseph w.'s Avatar
the leaf springs are weak, but all the bushings and mounts have been replaced. ive mounted the battery out back, but no 4-link. i have semi-soft tires, but ive just ordered some BFGoodrich T/A drag radials(275/50-R15) out of summit, they arent here yet though. the posi-trac.... a friend of mine has a set of 3:08 posi i can get from him, what will that gear change from a 3:72 to a 3:08 do for my milage and times? im on a tight budget, would rail-road irons out back help?
Old 01-29-2005, 02:29 PM
RCastle's Avatar
While weak springs may not be the whole to the problem,they definently contribute to the proble.When you take off,everything is "soaked" up into your suspension,You do not have posi,so your r/t wheel is bitting,creating lift,two opposite forces working against each other,causing a ripple effect in your springs. If you are off too much it will cause things to break.New leaf springs are not too awful expensive and relatively easy to replace,especially if a few buds help you remove the bed to do the job.Contact a sho pthat repairs diesels,like an independant shop,some places can even make them to order for you. I replaced the ones under my 2nd gen Camaro I used to own,it only cost me about $65.00 for the set. I do not think I got a deal on them but I may have,since I was in there every day for truck and trailer springs.Now those get heavy and hard to put in at times!!!!!!
Old 01-30-2005, 05:57 AM
Yup, pick ups are to light in the rear, need to transfer weight front to rear faster and more when you launch
el cheapo soft do nothing shocks on the front
add a 1/2"-1" of washers to the D side sway bar link, preloads the R rear
bag of sand R rear
raise the front (rubber spring blocks?)
lower the rear (blocks? clamp the springs?)
Consider all the above as a "tuning" kit that you can swap and change and test to help find what will be the best parts to buy (drag shocks, springs, etc)
? Not sure I agree with RCastle, may need more "squat" in the rear, even softer springs= more weight transfer, "playing" with the tuning kit above will tell you, try stiffening the rear also
Just think about this, it is funny to watch a stock pick up TRY to pull out a boat on a wet ramp or TRY to start to move on ice
Old 01-30-2005, 06:38 AM
poncho62's Avatar
Wiki Edits: 5
Put a load of bricks in the back.......................that's what a truck is for, it's NOT a race car.
BTW, yours must be one special 305. Most will hardly turn the tires................
Ontario Rodders
Old 01-30-2005, 09:02 AM
Littlered wagon's Avatar
New Member
Cal-Trac bars
Calvert racing sells traction bars that work really good CE has copy cat style called slide a link or something like that.Give em a try.
Old 01-30-2005, 10:22 AM
WakBordr7387's Avatar
Gone fishin'
Last wiki edit: Removing stuck fasteners
Last journal entry: blah.......again
Wiki Edits: 2
I agree with poncho, adding a little weight in the back is the cheapest and easiest way. I have the same truck as you and it makes a huge difference on traction with a little weight in the bed.
Also, my old 305 could turn the tires pretty good, if it was uphill and raining with almost bald tires, but if it was dry and level, it could sometimes give a little bark.
Old 01-30-2005, 10:52 AM
joseph w.'s Avatar
thanks for all the help guys. i know its crazy to have a 305 doing this, but its true, every bit of it. when it brokethe tranny crosmember bolts, i didnt believe it myself, but, when you have to pick up the peices yourself, you have to believe it... like i say, the transmission has a lot of money in it, i mean a lot. i dont think its the motor as much as it is the transmission. its already lowered 3 inches in the back and 4 in the front, i know thats not helping. would bigger wheels? and tires help? i was thinking 17's. im putting a piece of railroad iron out back when i get her running again... have a fuel line malfunction now. this iron should add about 100 lbs. to the rear, and im putting it at the very back right behind the bumper, i figure the farther back the better.
Old 01-30-2005, 11:16 AM
lluciano77's Avatar
Short changed on common sense
I don't know why you are breaking trans mounts etc.
Did you run solid motor mounts?
Old 01-30-2005, 11:20 AM
joseph w.'s Avatar
no, no solid mounts, like i say, this is a daily driver. when it does grab traction, itll slam your head against the back glass, and youll say bad words. all i know is tires are getting expensive and i have a headache.
