How can I identify a GM clip? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-17-2013, 01:09 PM
Inherited a 46 Ford frame with what is supposed to be a Chevy front clip. The price was right (Free for some labor). It was under a 46 coupe,but the new owner is going ALL Ford. The frame is boxed and is in good shape, power steering and disc brakes. I would like to freshen it up and use it under another 46, but need to know what it is before buying any parts. Any one help me out? Thanks in advance.
Old 09-17-2013, 01:15 PM
Banned
pictures would help alot
Old 09-17-2013, 01:52 PM
Faith - Respect - Trust
The most commonly used front clip or subframe from GM is from the 67 to 69 Camaro which is virtually identical (some cosmetic changes only) to the 68 to 74 Nova. If you have drum brakes...what size are the drums or if it's a disc brake, what size are the discs. The front drums on these cars where 9 1/2" inside diameter, the rotors where 11 inches across. If the rotors are of the stock variety and or the brake drums are 9 1/2 inches inside diameter, you have a 67 to 69 Camaro or 68 to 74 Nova front subframe. Ball joints, tie rod ends, control arms, everything is interchangeable and one of the reasons why this subframe was a favorite.
Hope this helps.
Ray
Old 09-17-2013, 04:05 PM
poncho62's Avatar
Wiki Edits: 5
If it is front steer (tie rods in front of crossmember), it is a 75 or newer. That is if its a Camaro/Nova subframe at all....It may be a "G" body clip, who knows....pics would help a lot
Old 09-21-2013, 05:11 PM
identifing a Chevy front clip
Heres some pics of the clip I inherited.
ID:	82713   Click image for larger version
ID:	82721   Click image for larger version
ID:	82729   Click image for larger version
ID:	82737   Click image for larger version
Old 09-22-2013, 10:04 AM
kso's Avatar
kso kso is offline
With the front steer it's not a '67-69 "F" or '68-74 "X". With the frame horns configured for bumper cylinders, it's late-'70s at-least. Few used '73-77 "A"s (Chevelle etc)... Here is a pic of a '78 "A" (Malibu) which carried through the '80s and was later re-designated "G". Note the difference at the front of the crossmember and in the upper a-arm mount area...so it's not one of those.
My guess is yours could possibly be a '73-77 Chevelle but much more likely a late-'70s-'81 "F" (Camaro/Firebird) or "X" (Cadillac Seville), same thing. It appears also those are the "tall" spindles, which would confirm that. People like to use those (instead of the Chevelle) because the frame rails go straight back after the crossmember rather than curve right away into a perimeter frame, which makes for some easier fabrication. The downside is width, at about 3" wider than a later-model "A"/"G" or early-"F".
Old 09-22-2013, 05:29 PM
It's a 74 or 75 Camaro clip,
Old 09-22-2013, 08:30 PM
life is a temporary assignment
78-80 Camaro..
Same thing I put on my 57 chevy..
Old 09-27-2013, 05:32 PM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
Looks like my 77 Camaro clip ,,same 74-81
I think you have a Camaro clip connected to I think a 46-48 ford CONVERTIBLE frame
Can anyone help me identify this tc rock_dog Transmission - Rearend 7 08-27-2012 10:15 PM
Help me identify this.......... 53_belair Transmission - Rearend 2 11-09-2006 09:17 AM
Clip the front of a 59 Chevy pu with a 70 Camaro Front clip? Will it work? classicappraiser General Rodding Tech 6 10-16-2006 12:05 PM
Can you identify these? Brazz_04 Hotrodders' Lounge 10 09-20-2005 11:58 AM
need help to identify digitalfrek Engine 2 11-16-2003 08:07 PM
