"Olde Gear Head"
As to your 400 SBC
Achieving 500 HP is possible but longevity is medium at best Recommend start with '70 to 72 4BM blocks Have built several "street" 400's Some 2BM's but really recommend the 4BM block Getting hard to find as they only used 4BM for those above years 4 BM had inherent weak points in center 3 main webs If using laughing gas or boost or planning to twist this engine past 5500, recommend lower end studs and billet caps Have one of my 500 (yes, actual 501 HP Dyno'ed) 400 + 30 engines in a '78 Malibu and it runs great Not really that radical Has AC! Hope this helps-more info if needed |
Use flat top pistons @ zero deck, a set of Etec 200 heads or equivelent, an Ede 2201 roller cam and lifers, an RPM Air Gap manifold and a highly tuned 680 to 750 cfm QFT carb. Limit advance curve to 16*, set initial at 20*, 36* total at 3000 rpm, add 10* of vacuum advance plugged into full manifold vacuum and enjoy about 480 hp and about 510 lb/ft of torque with gorgeous streetability. BTW, peak power is all in at about 5800 rpm.
400
You can build a better engine, a 383. I can tell you how.
The other advice, well to much compression is the enemy with a 400 from there 5.7 rods and other things will make an OK engine. Have good caps put on a 2 bolt, 400$ min. but, 305s and 400s are junk for the most part. Dont go more than .020 over if you can help it, siamese cylinders with little material for the head gasket, I could go on but some 400 lover will tell me Im wrong. |
| how much horsepower | kingj | Hotrodding Basics | 10 | 12-31-2008 05:37 PM |
| horsepower | oldschool | Engine | 3 | 01-10-2006 07:46 PM |
| how much horsepower | kingj | Engine | 1 | 12-12-2005 03:48 PM |
| Horsepower.... and horsepower loss | PonchoTA79400 | Engine | 3 | 03-13-2004 09:25 AM |
| need more horsepower | armyaj33 | Hotrodding Basics | 9 | 02-20-2004 11:57 PM |
