how can I raise the front of my 1937 Ford
I have a 1937 ford with a Downs body & chassis. a small block Chevy in it. It has coil overs on the front & the adjustment is screwed way up to the top. Compressing the spring a lot, & not giving the suspension much travel. & the car still sits too low & the front tires need a little more clearance. Does anyone have an idea to raise it up an inch or two?
thanks. Roger |
Do you know if it has dropped Spindles on it? Tha is a typical modification, and if it does, you could go back to "standard" Spindles which would raise it up-whose front end is it?
I'm sorry, I have to ask this question, where is the adjustment nut at the top of the shock or the bottom?
http://content.mamotorworks.com/img300/fr11482.jpg On the above photo the shock on the right screwing the adjustment nut "all the way to the top" would LOWER the car. The one on the left screwing the adjustment nut "all the way to the top" would RAISE the car. Let's just be sure we are on the same page here. Brian |
| All times are GMT -6. The time now is 08:54 PM. |
