how can I raise the front of my 1937 Ford - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-15-2012, 09:56 PM
I have a 1937 ford with a Downs body & chassis. a small block Chevy in it. It has coil overs on the front & the adjustment is screwed way up to the top. Compressing the spring a lot, & not giving the suspension much travel. & the car still sits too low & the front tires need a little more clearance. Does anyone have an idea to raise it up an inch or two?
thanks.
Roger
Old 06-18-2012, 08:11 AM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
Do you know if it has dropped Spindles on it? Tha is a typical modification, and if it does, you could go back to "standard" Spindles which would raise it up-whose front end is it?
Old 06-18-2012, 03:20 PM
I'm sorry, I have to ask this question, where is the adjustment nut at the top of the shock or the bottom?
On the above photo the shock on the right screwing the adjustment nut "all the way to the top" would LOWER the car.
The one on the left screwing the adjustment nut "all the way to the top" would RAISE the car. Let's just be sure we are on the same page here.
Old 06-24-2012, 10:46 PM
thanks.
Roger
I'm sorry, I forgot to mention it has a Mustang 2 front end. & my coil over shocks adjust from the bottom, & the adjustment is screwed almost all the way up.
1937 ford 4 door/ 1937 coupe roof contour bobrob12 Body - Exterior 0 03-12-2012 07:45 PM
raise the front end bughunter Suspension - Brakes - Steering 3 09-27-2009 09:21 PM
Mopar front to LOW , How 2 Raise? Lewissr Suspension - Brakes - Steering 5 12-02-2002 05:37 PM
raise the front end of the Chevelle tetzlaff Suspension - Brakes - Steering 3 09-19-2002 11:22 AM
