how can i tell if i have a posi rear end?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-12-2010, 11:56 PM
is there a way to tell if i have a posi rear end without burning some rubber?
Old 09-13-2010, 01:13 AM
59gmcfleetoption's Avatar
Ya jack the rear end up and turn one tire and If both tire turn then it has posi or take the rear end cover off and look inside. Or roast the tires that best way to check
Old 09-13-2010, 03:02 AM
83elky's Avatar
I give it 110% 90% of the time
Last journal entry: More pics of my garage..
If both turn THE SAME WAY is the key here. if one turns opposite from the other then it is not posi
Old 09-13-2010, 10:06 AM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
If you jack up both wheels and can't turn them without taking it out of park or taking it out of gear it is a posi . Also as previously mentioned , If it is in park or gear and you turn one wheel and the other goes in the opposite rotation it is NOT a posi .
Old 09-13-2010, 11:03 AM
big gear head's Avatar
High Performance Rear Ends
The only sure way to tell is to remove the cover and look at it. Any other way can fool you.
Old 09-13-2010, 12:22 PM
thanks ima jack it up to check later i kinda dont want to take the cover off cause i couldn't find a gasket for it when i drained it like 8 months ago so i made one, and its been holding up but i dont wanna mess with well enough......
if its not a posi how much is the upgrade going for?
Old 09-13-2010, 12:50 PM
What rear end are you working on?
Rear end swap required & I'm cunfussed datsun dale Transmission - Rearend 8 12-17-2008 09:03 AM
84 Z28 Rear End TO Posi Traction Conversion x711 Transmission - Rearend 2 08-07-2006 07:51 PM
82-92 camaro posi rear end info NoEgoMan100 Transmission - Rearend 4 10-21-2005 02:22 PM
'79 seville Rear end Posi??? MrChevyDC3 Transmission - Rearend 10 12-28-2004 10:11 PM
75 dodge half ton posi rear end 81elcamino Transmission - Rearend 0 10-26-2003 02:33 PM
