How can i tell if its a 350 or 305???? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-08-2007, 03:45 PM
camarodude87's Avatar
I have a 83 camaro. NoT A Z28, just a plain ol camaro. But in 83 the biggest engine it came with was a 305, I ran the number on the block and i found out that its a L98 or 89 something alone those lines and it was in the 79 z28. Will those numbers be on a 305 also? Is there any part, like a starter or something i can look up to see what i got.
Ray
Old 03-08-2007, 03:53 PM
RippinRon's Avatar
A L-89 is a 427 big block and the L-98 is a aluminum headed 350 from 3rd gen. f-bodies and C4 vettes. The L-98 were tuned port injection. Check the casting numbers at Mortec .
ID:	19273   Click image for larger version
Old 03-08-2007, 03:55 PM
I aint no expert, thats why im asking. So is there any why i can tell?
Old 03-08-2007, 04:10 PM
As stated earlier:
Check the casting numbers at Mortec.com
Old 03-08-2007, 04:16 PM
RippinRon's Avatar
What are the numbers on the block?? Look at the picture I attached to get the locations. Compare your heads to the other picture. Remove a valve cover to get the casting number off the head if you don't mind spending a couple bucks on some new gaskets. They are probably leaking after 25 years anyways.
Old 03-08-2007, 08:34 PM
Lonestar's Avatar
"May the Schwartz be with you"
Last journal entry: Finally getting going...
Ray
Post the numbers...
1991 Firebird: Conversion from 305 to 350 Chevy21 Engine 6 03-22-2005 12:28 AM
Will this work? Chevy 305 Throttle Body w/ Chevy 350 aberg12012 Engine 9 05-07-2004 12:28 AM
Will chevy 305 HO heads fit on a 350? sugarmonkey Engine 5 01-16-2004 07:07 AM
350 Heads on 305? JohnyR17 Engine 6 01-05-2004 08:53 PM
305 vs. 350 question DesertPanel General Rodding Tech 4 10-16-2003 08:19 PM
