how can I tell if my rearend is posi in my 84 z28 - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-08-2012, 05:28 PM
WDCreech's Avatar
Grumpy Old Goat Herder
To figure out what ratio you have, put one wheel on the ground, spin the other one TWO revolutions, and count the revolutions of the driveline. Since there is a 2 to 1 reduction in the spider gears, the number of revs that the driveshaft spins to 2 revolutions of the tire, will be your gear ratio.
  #17 (permalink)
Old 03-08-2012, 05:34 PM
91camaroRS3.1
well, i guess that settels it...lol can we see a pic of the hotrod?
  #18 (permalink)
Old 03-08-2012, 06:35 PM
prostreet6t9's Avatar
Differential/Driveline
I would just pull the rear cover and look. You could probably use some fresh oil anyway.
65 ford posi rearend jimmylorrain Transmission - Rearend 4 12-29-2011 02:39 PM
Posi Rearend GMC R1500 Transmission - Rearend 7 01-01-2010 05:08 PM
How to tell if I have a posi.traction rearend shockers69 Transmission - Rearend 9 04-02-2004 12:28 AM
posi rearend robbysapien Engine 1 08-19-2003 11:34 PM
posi rearend ? inkfixer73 Engine 3 08-17-2003 12:47 AM
