how can I tell if my rearend is posi in my 84 z28
How can I tell from the numbers on my rearend if its a posi? I believe It says GM N 22522676D A04 K2
well there is a simple way. lay some rubber. if theres 2 black marks it is..if theres one...its not.
Even an Open Carrier can also lay 2 stripes so that's actually not a good method.
Jack up the Rear, rotate one wheel in either direction, if the other wheel rotates the opposite direction it's a Posi. Even this method can be skewed if the Posi is worn out. Remove the cover & check. Stock Camaro would have an Auburn Posi Carrier. http://rides.webshots.com/photo/1055...41712107aYpqsX Or Open Carrier. http://rides.webshots.com/photo/1055...41712107SBwwbO Pics courtesy of 'BigGearHead" |
I thought a ''posi'' rearend : the tires on each side of the differential would rotate the same direction if the posi is operational?
At the Bonneville Salt Flats, first gear is known as 130 mph. |
Im with Crosley on this one, I have a posi in my camaro and it came out of 92 Z28 and both wheels turn the same direction on both sides when jacked up and spun. I have a 82 camaro standaed rear end and when one side turns the other side spins in the oppisite direction of the other when jacked up and turned by hand.
Rear gear ratio??
If Posi, raise rear & turn wheel 1 Rev, count turns of Driveshaft. If Open, raise 1 wheel & turn 2 Revs, count turns of Driveshaft. 3 & 3/4 turns = 3.73 3 & 1/2 turns = 3.42/3.55 etc.................. |
Ok I hope this dont sound stupid ......... raised the car all four in the air now when i spin the driver side the passinger side rotates the opposite direction but when i spin the passenger side the driver side does nothing. counting rotations of the driveline would you believe if i said it looks like the driveline and the wheel are about one for one? Check it out i take off in third gear so my wheels dont spin this thing dont know the meaning casual
burnouts for thw win.
i still belive my experimentm although might have not been conclusive, was still the most excting...lol
![]() "smell them burnin tires?" |
Brian |
theres gotta be sight saying wether or not this car came with a posi. not sure if my 91 rs is or not..i doubt it because its the crap box 3.1 v6 option. but ya never know.
There is no more discussion about it whether it is or isn't, you have proven that it isn't. Discussion on what posi is or what every sure, we can still talk. But it is NOT a posi. Brian |
| 65 ford posi rearend | jimmylorrain | Transmission - Rearend | 4 | 12-29-2011 01:39 PM |
| Posi Rearend | GMC R1500 | Transmission - Rearend | 7 | 01-01-2010 04:08 PM |
| How to tell if I have a posi.traction rearend | shockers69 | Transmission - Rearend | 9 | 04-01-2004 11:28 PM |
| posi rearend | robbysapien | Engine | 1 | 08-19-2003 10:34 PM |
| posi rearend ? | inkfixer73 | Engine | 3 | 08-16-2003 11:47 PM |
