How can i tell if my tranny is a 700r4 or a th350? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-20-2002, 02:34 PM
Rubberman2003's Avatar
Post How can i tell if my tranny is a 700r4 or a th350?
i pulled the engine and tranny, tranny has a sticker says is was rebuilt blah blah, some serial numbers, i just wanted to know if anyone could tell me how i can tell which it is by looking at it, thanks
Old 10-20-2002, 03:59 PM
Post
look on left side (drivers side) If there is an electrical connector that is about 3/4" square with 4 connectors, then it is either a 200r or 700R4. It will be bigger than a 350. You evidently did not consider that it could also be a T400??
Old 10-20-2002, 04:50 PM
BOBCRMAN@aol.com's Avatar
Post
the 700r has a pan that is rectangular in shape the 350 has a pan that is almost square but has one corner cut off at an angle. the 400 has a pan that is sguare at the front with a notch and a roundish protrusion at the rear(how's that for a description roundish protrusion!) some 350 turbos also have the 4prong outlet. 400 electrics are round with 1or 2 prongs depending on model
Old 10-20-2002, 05:58 PM
Post
Go to page 10 of trans & rearends, look at WILLYS36 thread. [table of rearend and front end dimensions] This will answer all your questions.
Old 10-20-2002, 09:19 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
The trans spotter guide is also posted on my photo album above.
Old 10-20-2002, 09:52 PM
Croz's Avatar
Hotrodders.com moderator
Post
wait, isn't a 700r4 a four speed? like having an overdrive? couldn't you drive it to tell? or was it not in a running vehicle?
Old 10-20-2002, 10:00 PM
Croz's Avatar
Post
here, i got a picture of a new one of each from Jet performance products out of my OPGI catalog.
hope this helps a bit.
[ October 20, 2002: Message edited by: Croz ]</p>
