How can I tell if the transmission has been rebuilt - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-18-2012, 07:39 AM
Hi,
I pulled the trany and engine yesterday. My plan is to rebuild most of the engine myself, but send the trany to a shop to get it done. The trany is
an E4OD. The vehicle has 165K.
After pulling it, I saw there was a very new looking, rebuilt torque converter in there, has markings to show it is a remanufactured unit. I have no way of knowing if the unit has been recently rebuilt. There was very little gray build up in the pan and the fluid looked and smelled good.
This is my question:
How can I tell if it has been rebuilt.
Old 12-18-2012, 09:31 AM
Too late to edit and I think I left out some important details.
I never drove the truck, so I don't know how the trany shifted.
Trany is covered in oil from a leaking rear main, or oil pan.
So it is not a brand new rebuild.
What can I check or measure to determine wear and possible life left till the next rebuild. Since it is out, I can get it rebuilt for less than $1,000. But that is money I wouldn't mind keeping in my pocket.
I do realize I can put it back in as is and then see, but like I said, it is out now and replicating work is a little annoying.
Thanks
Old 12-18-2012, 05:39 PM
1971BB427's Avatar
Short of tearing it down, it's impossible to deiscern if it's rebuilt. Even a new pan gasket wont indicate anything but a recent service. You'll either have to trust a trans shop, or roll the dice and put it in to see how it works.
The Following User Says Thank You to 1971BB427 For This Useful Post:
Infinite Monkeys (12-18-2012)
Old 12-18-2012, 07:16 PM
You made a very good point, one that I had over looked. It has a new torque converter, but the pan gasket looks to be old and brittle.
Is it possible, the converter could have been replaced without draining the pan?
Also, I just took the heads off and found:
2 exhaust manifold bolts missing and 1 broken in the head
2 bent push rods
Engine's been running on 5 cylinders (it's a Ford 460)
Broken timing chain cover
Cross threaded spark plug
That's just the top end. I haven't looked inside yet.
I hope the same person that took care of it last time did not also "rebuild" the trany.
So with that said.........The trany is going in for a rebuild.
Thanks
Old 12-18-2012, 09:05 PM
1971BB427's Avatar
2 bent push rods
Thanks
Sounds like a lot of neglect and misuse. Time for a fresh start.
Yes, it's totally possible to replace the converter and not drop the pan. Might have to top off a little fluid.
Old 12-19-2012, 10:58 AM
SSedan64's Avatar
Drop the Trans Pan & see how much sediment/debri is in the bottom, will give an indication of clutch wear. Much of it could be from the TCC/TorqueConverterClutch which may be why the TC was replaced.
Dark color = Clutch material.
Shiny, silver etc. = Metal, bushings, Clutch steels etc..
The Following User Says Thank You to SSedan64 For This Useful Post:
Infinite Monkeys (12-19-2012)
Old 12-19-2012, 11:20 AM
I checked the pan. It actually looked pretty good. Very fine layer of gray sediment. Outside of trany is covered in oil and dirt. This is what makes me think that just the TC was replaced and not a total rebuild. I would assume the outside would have been a lot cleaner if it was a total rebuild. I'll also try and find a trust worthy shop. But who wouldn't want the money.....
Thanks
Old 12-19-2012, 02:32 PM
1971BB427's Avatar
Torque converter clutch?
Old 12-19-2012, 03:18 PM
So, now I'm considering the possibility that the TC was replaced, but the trany is actually just fine?
Any thoughts.
Thanks
Old 12-19-2012, 05:37 PM
1971BB427's Avatar
It's not that big a deal to drop an automatic with a trans jack, if it doesn't work out to be good. I'd try it and see how it works first.
Old 12-19-2012, 05:53 PM
I think my greed is getting to me. $1000 is a lot of money and I'm not swimming in it.
The extra work is worth it........
So now before I can put it back in as is. I have to fix my OH SH^&.
Here's what I did. While removing the shifter cable from the shift lever, I got my lefty/loosey, righty/thighty mixed up and turned the nut the wrong way.
Soon there after I heard a snap and a small clank in the trany pan. I'll have to fix what ever I broke before it will shift in a out of gears.
I'll concentrate on the engine for now. Once thats in the machine shop, I'll see what I broke in the trany. That will another post.
Thanks again.
Old 12-21-2012, 07:17 AM
SSedan64's Avatar
Lockup Clutch inside the Torque Converter. Common problem in the E4OD and other OD Trans.
Pics of a Lockup TC >> Phoenix Transmission Products | 700R4 - TH-2004R - TH-350 - 4L80E - High Performance Transmission Products
Infinite Monkeys (12-21-2012)
Rebuilt Manual Transmission Won't Shift Into Any Gear? RichieB Transmission - Rearend 17 11-15-2011 08:44 PM
fresh rebuilt turbo 350 transmission hardly shifts into reverse and no forward gears 79malibuclassic Transmission - Rearend 3 04-11-2011 12:00 AM
1995 Impala Rebuilt Transmission Shift & Noise Problem Mobbvalous Transmission - Rearend 2 12-31-2008 04:50 PM
Rebuilt transmission use by date. ron2003_h Transmission - Rearend 3 07-10-2008 11:47 PM
Rebuilt vs New - What's Best? dbuff General Rodding Tech 5 07-23-2004 09:54 PM
