Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How can I turn the Flywheel to get access to convert bolts
Old 04-14-2012, 10:39 PM
timothale timothale is offline
Wiki Edits: 27
pry bar
I have a 472 caddy running my saw mill. It sat for about 10 years not used. I pulled the plugs, shot in some oil then pulled the starter and used a pry bar on the teeth , worked it back and forth to loosen it up. I fired it up, ran good, and i worked it pretty hard cutting some large juniper logs, It's time to get a good battery, gas and just run it for a while.
