How can you tell solid from hyd. cam? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-14-2009, 08:53 AM
redride's Avatar
1969 Nova SS502
Ok guys here is what is going on. I have a 396 that I am replacing with a 505 but I am going to use my roller rockers from the 396. When I measured for pushrods in my new motor I put the 396 on TDC and pulled the rocker arm off to measure the pushrod length with in my 505. When I put the rocker arm back on my 396 I ran the nut down on the rocker arm and set it with 1/2 turn after the pushrod was against the lifter and started the 396 which was running real rough. I turned the car off and found a plug wire off on #3 and put it back on and then started the car again, still running rough. I have had a problem with this motor having a dead cylinder after it sits for a few weeks and it clears up when I drive it. I got to thinking I do not even know if the cam in the 396 is a solid or a hyd. because it was in the car when I purchased it. My concern is what if it was a solid lift cam and I did not set the lash but ran the motor for about 1 minute. How do I tell with the motor in the car if it is solid or hyd? Could I have ruined something when I started the motor. I know this was a dumb thing to do but it is a little late for that now. Any ideas???
Old 03-14-2009, 12:12 PM
DoubleVision's Avatar
In most cases solid lifters tick and have to be adjusted after a while. Hydraulic lifters are quiet and pretty much adjustment free after they are set the first time.
One difference in the lifters are the solids are just that, solid, the lifter is a 1 piece design, under the plunger where the pushrod rides is also solid, and this is why they are adjusted using a feeler gauge so the clearence is set correctly.
A Hydraulic lifter has a cavaty under the plunger that fills with oil so they have a wide range they can be adjusted to since oil will bleed down the tighter it`s adjusted and the lifter will set itself to run at this adjustment.
If my explanation just confuses you more, then here`s a article.
http://www.popularhotrodding.com/eng...ic_lifter.html
Old 03-14-2009, 12:21 PM
redride's Avatar
1969 Nova SS502
Thanks for the post. I understand the difference in the two lifters but I do not know how to determine what I have under the cercumstances. The 396 is in the car with the intake on. I can pull the valve cover back off, pull the rocker arm and pushrod and look down in the block and see the lifter but do not know if a solid lifter will look different than a hyd. I do not hear real well so as far as the ticking I am of no use. I guess I could pull the valve cover and check to see if there is a clerance under any of the other rocker arms. I would think that if it is a solid that the others would have some slack between the roller tip and the end of the valve stem. Correct?
Old 03-14-2009, 05:15 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
A solid lifter will impart a shock through the pushrod to the rocker that can be felt.
With the engine running and the valve covers off, place your thumb on the rocker, over the push rod. You should be able to feel a distinct shock that isn't there on a hydraulic lifter engine.
This is basically how you determine zero lash on a running hydraulic cammed engine when setting the valves. On a solid cam, the looseness will be felt on all the rockers. More noticeable when cold, usually.
Hope this makes sense.
Old 03-14-2009, 06:44 PM
redride's Avatar
1969 Nova SS502
Thanks guys
Old 03-15-2009, 11:47 PM
Not a cam expert here but I wanted to also add that another check is to tighten to just zero lash with the lifter on cam base circle and if it's a mechanical cam then it should suddenly get really tight and cause the rocker to depress the valve as opposed to the lifter plunger if I'm not mistaken.
Solid vs Hyd. Lifters...AGAIN Fastest65 Engine 12 08-26-2008 04:35 PM
BBC 454 - Cam Selection - Solid vs Hydraulic - Help me Choose leejoy Engine 1 11-11-2007 04:45 PM
valve lash on a bbc solid cam elanum70velle Engine 4 07-01-2006 10:45 AM
Solid vs Hyd Cam choice Dubz Engine 6 03-08-2004 10:15 AM
hydrolic lifter cam vs. solid lifter cam chevyelc81 Engine 12 09-09-2003 07:38 PM
