How To Change Distributor On 93 5.7l Tbi? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-07-2010, 02:55 PM
Hi guys just got my truck back from the STEALERSHIP saying my dist shaft was cracked and dist itself was full of corosion and rust... hoping this will fix my rough idle I am going to change it myself along with the pick up, cap, and rotor, for around 300 instead of paying close to 1000 for parts and labour anyways wha do i have to watch for is it fairly simple change? do i ahve to retime motor? any help would be appreciated! thanks
Old 10-07-2010, 03:24 PM
sbchevfreak's Avatar
Licenced Automotive Technician
The easy way is to mark on a stationary surface where the rotor is pointing, and then unbolt the hold down and pull the dizzy out. Drop the new one in so that the rotor lines up with the previous mark. Then re-timing is needed. Unplug the EST bypass wire (tan w/black tracer) located either in the main harness by the passenger side firewall, or it is under the dash on the passenger side at the carpet line by the blower motor. Second location is not that common. Set base ignition timing to zero degrees, shut engine off and reconnect EST bypass wire and you are done.
Old 10-07-2010, 03:31 PM
alright thanks alot appreciate it.... is the pick up coil easy to change also? First timer so am pretty new to this!
Old 10-07-2010, 04:01 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
One minor item, don't turn the motor over while the distributor is out, it'll change the oil pump drive rod slot orientation, you'll notice the distributor turns slightly as it drops down as the cam gear meshes, and turns the reluctor plate and rotor with it.
Semper Fi
350 TBI to 350 TBI VORTEC SWAP IWANTMOREHP Engine 8 10-20-2016 10:57 AM
Swapping Vortec heads onto 5.7L TBI yukon... TheZaZ Engine 2 05-30-2004 06:42 PM
TBI Questions on a 93' Chevy FS 350 IWANTMOREHP Engine 1 01-04-2004 02:42 PM
88-95 5.7l TBI engine.... good aftermarket cams?? TheZaZ Engine 6 03-03-2003 05:08 PM
350 GM Goodwrench Caprice engine in 3rd Gen TBI F-Body? wrmason3 Engine 2 09-14-2002 08:01 PM
