Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How to change oil in Ford 8"
Old 06-23-2011, 04:51 PM
T-bucket23's Avatar
T-bucket23 T-bucket23 is offline
Wiki Edits: 26
Originally Posted by yragat
' Ford rear has no drain plug. Any suggestions how to drain & refill without taking all apart??
A lot of the 8" housings didn't have a drain. You need to loosen the bolts and let it drain. Just fill it until it comes out of the fill hole. Unfortunately all the crap will be in the bottom of the housing so if you dont pull the axles and the pumpkin, most of the crap will remain in the housing.
Chet
