Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How to change oil in Ford 8"
Old 06-23-2011, 06:12 PM
yragat yragat is offline
Originally Posted by Irelands child
I guess I've never seen an 8" without a drain, but since they are so easy to pull the pumpkin - drive shaft, 4 nuts at each axle, 10 around the circumference and out it comes.
I truly hope there is no crud on the bottom. If there is, it WILL get expensive - soon.
To put a drain in the bottom, you not only need to drill the hole, you need to weld in a 'bung' for the threads. That housing is sheet metal, probably about 16ga. Ford punched a hole then threaded the raised steel on most of their rear ends
I didn't realize it was that thin of metal. Maybe I'll just wait till winter and tear it apart---too busy driving it now--don't know when or if oil was ever changed in it. Can't understand why Ford didn't put a drain in it????
