Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How to change oil in Ford 8"
Old 06-23-2011, 09:11 PM
enjenjo enjenjo is offline
Take one of the carrier mounting bolts loose on the bottom. With the nut just started on the bolt, knock the bolt into the housing with a hammer. The oil will drain around the bolt. Pull the bolt back into place with the nut, and refill.
