Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How to change oil in Ford 8"
Old 06-23-2011, 09:28 PM
yragat yragat is offline
Originally Posted by enjenjo
Take one of the carrier mounting bolts loose on the bottom. With the nut just started on the bolt, knock the bolt into the housing with a hammer. The oil will drain around the bolt. Pull the bolt back into place with the nut, and refill.
Thanks,I'll try that
Gary
