How to change oil in Ford 8" - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-23-2011, 03:12 PM
' Ford rear has no drain plug. Any suggestions how to drain & refill without taking all apart??
Old 06-23-2011, 03:57 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi yragat
Opening up the housing is the only way to do this. Also if your
changing over to synthetic gear oil, it's not compatible with Dino oil, so all the old stuff needs to be cleaned out very well.
Rich
PS Refill amount about 41/2 pints
Old 06-23-2011, 03:58 PM
You can buy a suction tool that will suck the oil out of the fill hole. Most oil change shops have such a tool as they dont usually drop the pan to change ATF.
Old 06-23-2011, 04:09 PM
Ẁhilst on the subject of ford axles I also need to know what type of oil and also how much is needed? in a 9 inch this is a dry axle as it just had a rebuild.
Old 06-23-2011, 04:16 PM
Hi MOPARINMYCAR
Your 9" is about 5 pints If your using Dino oil you want 90w
if using synthetic (synthetic is what I'd use) 75-90
Rich
Old 06-23-2011, 04:23 PM
Thanks for the quick reply Richard but what is dino oil ? sorry Im in the UK so not up tp speed with the US terminology
Old 06-23-2011, 04:32 PM
Dino oil is the standard oil you've been using for years, oil from the ground is referred to as Dino oil, decaying dinosaurs. I personally use only synthetic oils.
Rich
Old 06-23-2011, 04:51 PM
T-bucket23's Avatar
Wiki Edits: 26
A lot of the 8" housings didn't have a drain. You need to loosen the bolts and let it drain. Just fill it until it comes out of the fill hole. Unfortunately all the crap will be in the bottom of the housing so if you dont pull the axles and the pumpkin, most of the crap will remain in the housing.
Chet
Old 06-23-2011, 05:04 PM
I'm thinking about drilling the bottom and putting a 1/4" pipe plug in it or possibly one of the self tapping plugs they make-----whats the thoughts on that? I figure if any small shavings go in from the drill,maybe when the oil comes out it will bring them with it????
Old 06-23-2011, 05:55 PM
Irelands child's Avatar
I guess I've never seen an 8" without a drain, but since they are so easy to pull the pumpkin - drive shaft, 4 nuts at each axle, 10 around the circumference and out it comes.
I truly hope there is no crud on the bottom. If there is, it WILL get expensive - soon.
To put a drain in the bottom, you not only need to drill the hole, you need to weld in a 'bung' for the threads. That housing is sheet metal, probably about 16ga. Ford punched a hole then threaded the raised steel on most of their rear ends
Irelands child
Old 06-23-2011, 06:12 PM
I didn't realize it was that thin of metal. Maybe I'll just wait till winter and tear it apart---too busy driving it now--don't know when or if oil was ever changed in it. Can't understand why Ford didn't put a drain in it????
Old 06-23-2011, 08:37 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
It would have cost Henry another six bits.
Old 06-23-2011, 09:56 PM
sqzbox's Avatar
My pipes are my music
They put them on the gas tank.
Old 06-23-2011, 10:11 PM
Take one of the carrier mounting bolts loose on the bottom. With the nut just started on the bolt, knock the bolt into the housing with a hammer. The oil will drain around the bolt. Pull the bolt back into place with the nut, and refill.
Old 06-23-2011, 10:28 PM
Thanks,I'll try that
Gary
Change Ford 9" - 28 spline to 31 spline fredbaker Transmission - Rearend 5 09-27-2009 05:12 PM
Motion to change Docvette's position on the "top 25" editors banner lowROLLERchevy Hotrodders Site Suggestions and Help 7 04-21-2008 09:47 PM
14" to 16" tires gear ratio change? pi71 Transmission - Rearend 3 10-16-2007 08:57 PM
As my Late Father used to say "Things change". MARTINSR Hotrodders' Lounge 10 05-31-2007 11:30 AM
feedback on "fast change gaskets" Jon Transmission - Rearend 25 03-08-2006 07:36 PM
