How to Channel a 20's-30's Body - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-10-2005, 10:14 PM
DirtTracker26's Avatar
Last journal entry: At Last, she is on the road
Let's see some Hot Rodders experience (& Pictures) of how to Channel a Model A or any other 20's-30's body.
I have a '29 Model A Roadster that I'd like to set over the frame, but would like to see what other people have done, and HOW.
What worked and What didn't!
Thanks!
See my Project Journal
Old 04-11-2005, 04:08 PM
Last journal entry: 99 soft tail standard I painted
Hey Dirt......Im building a 28 tudoor.......chop channel,you know,old style.When we get to that stage,ill post some pics.By that time you will probably have it figured out......lol
Old 04-15-2005, 07:50 PM
antiquecar's Avatar
old car nut
The last car I channeled was a 33 Ply. coupe and it was chopped, channeled and sectioned. I was sixteen at the time and I am 59 now so my memory might be a little blurred but here is what I remember. The floor boards have to be removed and the body mounts removed. We made up a square tube frame but the original fame can be used but it must be narrowed so the body sits around the frame instead of on it. The firewall must be notched and new brackets made up which are mounted at the door pillars inside the body to rest on the frame. Depending upon how far you channel the body you may have to alter the doors or the will open into the frame. I don;t ever remember seeing a successful fully fender rod that was channeled but a fenderless one or cycle fenders looks good. Wis you luck and I will try and come up with some pictures
Jan
Old 04-16-2005, 03:04 AM
Weimer's Avatar
Kenneth Howard hates you...
Last journal entry: door pics smaller
Check out my photo Journal...Same concept/different car.
If you have any questions, send me a PM.
Later,
WEIMER
34 Ford body alignment 302 Z28 Body - Exterior 5 08-20-2012 06:10 PM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
"Basics of Basics" Sectioning a Body MARTINSR Body - Exterior 7 11-24-2008 12:04 PM
ATTENTION MEMBERS: CREATED mIRC CHANNEL FOR HOTRODDERS!!!! 78SilverShark Hotrodders' Lounge 11 09-08-2003 03:28 PM
Body channel 38Nash Body - Exterior 1 11-21-2002 05:58 PM
