Nope, just set the magnetic base on the flywheel and engage the magnet, with the arm and indicator in a position so that it will read off the bellhousing register hole(the hole that the transmission front bearing retainer pilots into)...then turn the crank one revolution and read the runout on the indicator(total needle movement).
Divide the amount read off the indicator in half and note the position of minimum runout...this is the direction the bellhousing has to be moved and the amount of offset needed to correct the package. |
| Best, easiest way to support engine for bellhousing alignment? | v8hed | Transmission - Rearend | 10 | 03-06-2011 07:02 AM |
| Looking to buy 621 bellhousing | usa3990 | Transmission - Rearend | 1 | 08-18-2010 06:37 PM |
| FMX FE bellhousing? | zatazuken | Transmission - Rearend | 1 | 10-04-2009 04:01 PM |
| Hyd. Roller Lifter Check.....Check | greenmoonshine | Engine | 11 | 07-22-2009 12:25 PM |
| Bellhousing | oldtimeydave | Engine | 3 | 05-13-2008 04:38 AM |
