How to check
There are a lot of ways to skin a cat, but I usually connect a DVOM to the battery and take an initial reading, we'll say it's 12.6 volts. Start your engine, turn on all of the lights, high speed heater fan, hazards and wipers. At 2000 rpm the voltage at the battery should be at least .5 volt higher than your initial reading. In our example that would be 13.1 volts. In real life you'll usually see 13.5 to 14.1 with a good alternator.
How to check
You would connect the red wire of your multimeter to the large stud on the back of the alternator. You connect the black wire of your multimeter to any good ground point on the engine or to the battery negative post. You can connect it to the alternator housing if you can get a good grip on it somewhere. Then follow the procedure I outlined before.
humm, i always did it the simple old fashion way. with car running disconnect the postive battery cable , if its not chargeing car shuts off........
Follow ernzakern's advice. You said charging, not properly charging. Charging is anything above 12 volts, properly charging with load would be somewhere between 13.5 ~ 14.6 approx. BTW KENMO, post some more art.......I need new backgrounds. Do you have a digital voltmeter to check charging voltage???? |
How to check
Wildthing........you're joking right? That's good way to ruin the ECM on a newer vehicle
How to check
Holder350, that just tells you it's charging, but doesn't tell you if it's charging enough to keep the battery charged under load.
Doc here, And if the battery is gassing .... It EXPLODES RIGHT IN YOUR FACE...tearing off the front end of the vehicle... AND IF the Diodes are bad .... The RAW AC generated and reverse biasing will DESTROY EVERY Electronic Component in the vehicle..Computer, ECM, Sensors, Alarm, CD?Players, High Power audio amps, Aftermarket Linear based op amp gauges and tachs..SINCE these will tolerate NO AC voltage on a source current line and the battery would have acted as a buffer.. NEVER>>>NEVER!!!! Pull a cable off a battery on a running vehicle!!IF you don't kill, blind or injure yourself...you probably have secondary damage that keeps occurring... Doc
Aftermarket Solutions Electronic & Electrical Innovations |
Doc here , All that tells you is that there is a magnetic field...and the windings aren't opened.. Not if the output is 37 volts AC, or 10.1 DC with a 4.3 AC residual, or 14.4 Volts DC... The ONLY to test i with a proper meter and testing procedures.. Doc
Doc here,
To properly test your Alternator for output, simply get a Meter, Analog or Digital, set it for DCV, VX20 or better scale.. Start and warm the car..let it warm up to curb Idle..about 5 minutes @ 950 RPM's Measure across the battery, it should read 14.4 volts if up to full capacity..anywhere between 13.95 and 14.4 is great...under 12.5 is a problem..over 15 is overcharging ... Simple as that.. Doc
| Things to check out when buying a new car | k2mooch | Hotrodders' Lounge | 7 | 08-17-2004 03:34 PM |
| Self Check Out //Fast Lane//-Stupid | Ghetto Jet | Hotrodders' Lounge | 25 | 07-27-2004 07:29 PM |
| s-10 carrier bearing, how do you check them | catscan4free | Transmission - Rearend | 2 | 01-24-2004 04:45 PM |
| What to check on used car? | CET | Hotrodders' Lounge | 4 | 01-10-2003 08:00 PM |
