how to check for jumping spark - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-04-2012, 08:18 PM
Every one in a while I hear the cracking of spark as I turn the engine on. The engine turns on fine but there is a definite "crack" of electricity. I read you can spray a light mist of water in the area to help bring out the problem. Will this work or will I burn some thing up. The truck runs fine now but I am worried that when it rains the issue will get worse and leave me stranded. I have also ran the engine on the dark but did not see anything.
I did recently install a external coil on my HEI.
Old 06-05-2012, 06:39 AM
67Mustang Al.'s Avatar
Stray sparks.
Maybe a close look at all the boots on top of the cap, coil and plugs is needed. High voltage from the coil is a good place to start. Plug leads may be at the end of their life. Check all the earth connections.Voltage will be highest from the coil at cranking speed which is when the problem is likely to occur. Maybe someone watches the coil in the dark while you crank it over.
Cheers
Al.
Spark plug wires jumping spark STATUTORY GRAPE Engine 4 10-04-2009 06:14 AM
how soon can i check the spark plugs SBCfan04 Engine 7 04-01-2009 07:35 AM
Heat range (Spark plug) reality check driveability Engine 0 01-19-2007 01:34 AM
HELP! spark jumping from wires to the plugs like crazy (long post)!!!!!!!! Blown72Camaro Engine 8 06-22-2004 09:01 PM
Spark Check bluesman123 Engine 4 08-18-2003 10:42 PM
