How to check pushrods? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2004, 08:36 AM
Still and always looking for the knocking source of my 383 stroker.
The pushrods are standard length for SBC . I checked them rolling them one by one on a cast iron surface (my tablesaw) that looks straight...now I have found two or three that might show some unstraightness but so little that I wonder if it can affect on my engine. Pressing down one end of the pushrods there is some gap between the other end of the pushrod to the cast iron surface...now it is not much..maybe around 1/16 of an inch.
Is my method of checking them the right way and what do you think of such a small bend...enough to create knocking? I've just ran a compression test and it all came out at around 210 PSI with less than 10 pounds.
That darn knocking ,through the stetoscope, seems to be located on the lower end of the engine ....running the stetoscope along the side of the oil pan gives me a knocking..regular in strength wherever along the pan but not when the stetoscope is along the bottom of the pan...anyway so mostlikely the possible faulty pushrods sound like a farfetched possibility! I guess I am suffering of the shade tree mechanic's syndrome wich is to look at problems with rose sunglasses that bias the reality...
thank for the help..
Ronald.
Checking my post I need to precise that there was less than 10 pounds difference between cylinders compression wich ran around 210 PSI.
Old 06-13-2004, 09:23 AM
mstngjoe's Avatar
Good info on your pushrod question:
http://www.compcams.com/information/Products/Pushrods/
Old 06-13-2004, 10:49 AM
troy-curt's Avatar
Shop Owner And Troll Hunter
The slight bends in a few push rods will not cause a knock, how ever you should replace them with straight ones.
I check them the same way.
Troy
If you don't make mistakes. your not doing anything.
69 ss rs full custom camaro 98 ISCA grandchampion
69 ss rs bb camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 ss chevelle bb conv.fresh frame off
26 T sedan street rod
Old 06-13-2004, 10:57 AM
4 Jaw Chuck's Avatar
Pull the oil pan and start checking rod bearings first, sounds like your going to find one that is bad. Pushrods should be perfectly straight, a tolerance of 0.001" is about all I would accept.
Outlawed tunes from outlawed pipes
Old 06-13-2004, 11:01 AM
BstMech's Avatar
NYOFP4RJ3CHRIS
Diagram "A" in that website sure does seem to be assbackwards as far as which way the rocker tip sweeps the top of the stem.
Old 06-13-2004, 02:56 PM
Thanks fellows...I'm becoming an expert pulling the pan...it will be my third time now! I've had checked four rod bearings and one main a while ago and since they all looked new (this is a fresh rebuilt) I decided to look elsewhere this is when I discovered the slightly bent pushrods...so I've closed the pan and ordered new pushrods thinking I had found my problem but by the answers I have here it looks that pushrods cannot knock that way. Well I'll pull that pan again ....
Ronald.
Old 06-13-2004, 04:56 PM
Last journal entry: PICTURE TEST
knocking
Does this motor have a mechanical fuel pump???
If so remove the pump ans have someone start the motor for you and see if the sound goes away.
keith
Old 06-13-2004, 05:25 PM
Keith,
It has an electrical pump and a blocking plate where the mechanical pump normally mounts and there is no noise from there when I put the scope on it....
thanks.
Old 06-13-2004, 07:22 PM
71 c-10's Avatar
just a kid and his truck
could you of not clearanced the block enough and the counter weight or maybe a rod bolt are hitting it??
Old 06-14-2004, 09:51 AM
Maybe a cracked flywheel? Ive heard it before and it will resemble a knocking noise.....just a thought
Old 05-12-2007, 03:59 PM
383silverado's Avatar
niose in the bottom end
i'm no engine expert but i have heard that when you use forged pistons they have a tendency to rattle a little when you start your engine as aposed to Hypereutectic pistons they fit a little tighter in the cylinder walls this is just what i have heard
Old 05-12-2007, 04:33 PM
Dropthe oil filter, cut it open and spread it out, if you've got a bearing going away it will show up, usually as small aluminum colored flakes.
You've had the pan off since the knock started?? Was there any debris in it??
How about the crank hitting the pan?? Just helped assemble a 383 with an internally balanced crank, the rear counterweight was slightly hitting the pan, just enough that it would have caused a noise but no damage, a couple smacks with a ball peen fixed it.
Old 05-12-2007, 06:57 PM
engineczar's Avatar
3 year old post
BSE Racing Engines
