How to choose rims??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-16-2003, 06:32 PM
New Member
Post How to choose rims???
I have a mustang II front end and a 99 f150 rear end. The front and rear disks are both 5 lug and are the same bolt pattern. Someone said my rear end is hub centric and the front rotors are lug centric. After inspecting both they are different only in how the rim would mount. How do I choose rims? Would hub centric rims work on the front end as well as the rear if propper lug nuts were used?
Thanks,
Arb
Old 03-16-2003, 07:50 PM
BOBCRMAN@aol.com's Avatar
Post
if the bolt pattern is correct and the lugs are correct go to it!
