Is this how cleam my parts are supposed to be?
Hello everyone,
I have been fighting to get my sandblast cabinet to work properly and this is what I am getting (pics at bottom). I have a 5hp 60 gal compressor with drying rack and am using aluminum oxide media. This doesn't look as clean as it should be but to get it cleaner I have to hold the gun close and keep it there for awhile but that takes an unacceptably long time. I am currently using the smallest nozzle my set came with (don't have the exact size but smaller the 1/4 inch). Am I expecting too much or is my system falling short. ![]() ![]()
Heres the stuff you need to get that rust out.
http://www.1969supersport.com/sandblst.html fourth picture down, its $7 a bag now. But be carefull I use supplied air when i'm bead or sandblasting. Rob http://www.1969supersport.com |
Thanks guys,
I thought the Aluminum Oxide was the most aggressive media and don't even see the sand at the place I buy it: http://www.tptools.com/dg/183_Abrasi...ing-Media.html Is it called something else on their site? This place is close to me and I like getting stuff there. Thanks for the help. |
Heres where they use it.
Underlayment for Patios/Walks Epoxy systems & industrial coatings Specialized cement mixtures Landscaping Rob http://www.1969supersport.com |
I just love the labels on bags of play sand (that's what it is called on the bag) sold at Wally World, Home Depot, Lowes, etc-
The label lists such uses as play lots and children's sandboxes and this label is located just above the one that reads in bold letters "Caution do not breath dust created by this product, doing so can cause serious harm or death"!
DON'T belittle the dangers of breathing silica! It does not take much to cause some serious harm and you can get enough in one session with a sandblaster to cause some serious hurt or even kill you. There certainly is a lot of silica in the Earths crust but that is what's known as "bonded" silica and what we are talking about here is free silica. A sandblaster is nothing to snicker at and improper, or lack of, precautions to protect yourself from the dust produced from using silica containing sand can be deadly! |
Silica sand can also leave a residue that can hinder a paint job if not thoroughly cleaned. Most powder coating places recommend using an aluminum oxide over silica sand for that reason.
In a while, Chet. |
I heard that after removing the major rust you can soak it vineger to remove the rest. May be a better alternative to using a dangerous media.
Navel jelly or Ospho will dissolve out the remaining rust, get it at any of the home stores, Lowes, Home Depot, etc. The Ospho is a watery Phosphoric acid solution and the Navel jelly is just that, a jellied form of the same stuff. The Navel jelly will cling to surfaces and all you have to do is apply, let sit, brush with a stiff brush, repeat as necessary. Same thing with the Ospho except you have to stay with it to keep it wet. Advance Auto has a version of the Ospho called "The Right Stuff" I think and it is about the same thing only cheaper but Ospho is not expensive anyway. This is a mild acid (same acid found in soft drinks but in a stronger solution) that is very safe to use but be careful about spilling it on concrete or wood. Usually what I do is to use Ospho to remove the last traces of the rust then I wash it clean with soapy water then hit it with the blaster to remove any traces of the acid and flash rust from the soap and water rinse, leaves the metal completely clean.
| Recent Garage - Tools posts with photos |
| Maaco vs. At-Home Paint Job | nightrain_rod | Body - Exterior | 127 | 08-26-2012 03:07 AM |
| Prepping urethane bumpers and fiberglass parts? | starquest | Body - Exterior | 19 | 12-21-2007 09:54 AM |
| Hi, I am new!...I have asst. car parts.... | SBelk2003 | Introduce Yourself | 3 | 01-27-2006 06:04 PM |
| a place to look for parts for sale or post parts for sale | Jake_Dragon | Hotrodders Site Suggestions and Help | 5 | 07-26-2005 11:55 AM |
| 1964 Muncie M-20 parts question | 1964 Oldsmobile 442 | Transmission - Rearend | 3 | 04-10-2004 09:25 PM |
