How To Clean The Floor Pan - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2011, 11:15 AM
rj57's Avatar
Anyone know an easy way to clean the floor pan and frame?
Besides removing the body and using a rotisserie?
I need to clean the floor and frame of my first car. One thing I have working for (or against) me is the previous owner(s) allowed the transmission and rear end seal to leak for long periods. This softened the factory undercoating. But, it also makes for a very messy situation.
I tried using a wire brush on a high speed grinder. I am concerned about breathing all that dust it makes. This stuff is 50 plus years old and who knows what GM used to manufacture undercoating back then? Even wearing a paint mask I don't feel safe.
I can scrape a lot of the stuff off. But if there was a easier way to remove it, I'm open for suggestions.
A rotisserie would be great. But not in my budget.
Old 05-11-2011, 12:58 PM
I use a propane torch and a putty knife to get the majority off then wire brush it using solvent.Use some common sence with the torch,have a fire extenguisher handy but just don't get carried away with the torch.This method works fast and easy.
Old 05-12-2011, 06:05 AM
deadbodyman's Avatar
Wiki Edits: 11
This is how I do it too.
A few tips: use the defuser tip, you just want the heat so dont let the flame touch the undercoating and you just want to warm it up and it'll come right off ...If your working upside down,cover up ,that stuff sticks to skin like contact cement and it burns. take the carpet out....
Old 05-12-2011, 06:27 AM
shine's Avatar
SPI Thug
Last journal entry: some progress
use a heat gun . cheap at hf and wont burn down your garage.
Old 05-12-2011, 06:37 AM
Irelands child's Avatar
....and of course since acetylene is in short (or no) supply and the price has doubled, that heat gun looks even better
Irelands child
Old 05-12-2011, 07:38 AM
shine's Avatar
SPI Thug
more than one hotrod has been burnt to the ground by a torch. a cheap heat gun works better anyway. with a torch by the time you get it soft it ignites. heatgun will turn it to butter.
Old 05-12-2011, 10:17 AM
rj57's Avatar
Salvage yard I used to frequent, they told me about a few times they cut body pieces out for customers. One time they thought the fire was out. Even threw water on the spot they cut the metal from. Later that evening they had to call the fire department cause the undercoating re-ignited.
Old 05-12-2011, 04:09 PM
techinspector1's Avatar
Wiki Edits: 326
This one should be in the hot rod tips Hall of Fame!!
Old 05-13-2011, 06:07 AM
Wiki Edits: 11
Harbor freight?????? Not you too ,Shine......
No one should ever use acetylene to heat up undercoating ,what we use is the small ,blue Propane bottles...The diffuser tip is the wide ,oval tip that slips over the torch tip very little flame comes out. its what house painters use to strip paint off old wood houses.(by softening up the paint)..I'm sure someone ,somewhere could start a fire an burn down their garage with a propane torch but that same person would be using the heat gun outside in the rain.or painting a car with a kerosene salamander for heat.
.Someone mentioned using common sense....
I've used both, the heat gun works ,its just way too slow for me,especially if I'm working upside down and on my back..The feature I like most on my torch is the one finger on/off switch,you can set it down without fumbling around or using a striker to light it....
BTW, you dont need an open flame to start a car on fire, mig welders start more fires than a cutting torch ever did,Mostly because the danger is obvious and people are prepared if something goes wrong...Everything in this business is dangerous so...use common sense and be prepared ,just in case...Just having a water hose around isnt good enough and mostly useless for the type of fires that would happen working on cars...You NEED Fire extinguishers that are charged and properly rated....and dont go to HF for them either....
If your thinking of working on cars at your home the fire extinguishers go in before the car does...
What would you do with a clean 84 Z28? 6426yy Hotrodding Basics 7 01-10-2008 11:34 AM
clean blackbeard Suspension - Brakes - Steering 1 01-10-2005 07:23 PM
Clean PC johnsongrass1 Hotrodders' Lounge 15 01-03-2005 09:12 AM
One clean I6 Cruiseomatic Hotrodders' Lounge 6 09-13-2004 04:20 AM
clean up elcaminoescondito Body - Exterior 5 12-11-2002 01:03 PM
