How to clean Rust on my D0VE- A Heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-16-2008, 02:07 PM
Newbie Restorer
I am trying to clean up some surface rust on my DOVE- A heads that I am going to use for my 429 rebuild--Whats the best procedure to remove rust?? Wire brush? Chemicals? Sand Blasting? Emmory Clothe(Spelling)? Anyhelp would be nice!
Also, are did DOVE-A heads stock on 1970 429 engines (Mercury Cyclone to be specific)
Old 06-16-2008, 03:18 PM
Beadblasting followed by epoxy primer on the exterior before the rebuild works well, then before paint scuff the epoxy up with a scotchbrite.
Old 06-16-2008, 06:24 PM
FEDDO's Avatar
when you take the heads in for rebuild they will put them in the oven. that takes off most of the rust. the heads are 70 model,so should be right for your car.
RUST..What are the acceptable permanent ways to get rid of it? Rocket1 Body - Exterior 213 10-30-2011 07:23 AM
Rust inbetween Double Seem Questions Advice on ATTACK Plan fcastro Body - Exterior 3 01-22-2008 12:20 AM
olds #5 head johann Engine 1 07-30-2006 11:05 PM
LT-! Alum. Heads Quetions, Please? nite53 Engine 3 02-16-2006 09:09 AM
AFR Heads DTL504 Engine 9 12-09-2003 03:55 PM
