how close is 2 close, Pic - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-04-2010, 08:38 AM
daoldbuick's Avatar
As you can see from the pic my inner fender is only 1" from the front tube of the headers. Is that too close? Will it blister or burn the paint? As it's not a place you can see I was thinking I could put some of that reflective heat tape on that part of the fender. Would that help? What other options are there? As you can see I've put heat protecting cover over the AC hose that is close to that same header tube.
Also my rad cap is only about 1/32" from the hood. Is that to close? The top of the rad cap shouldn't get so hot it would damage the paint but I could be wrong so I though I'd ask..
The car is a 36 Buick if it makes any difference.
Old 10-04-2010, 12:10 PM
dinger's Avatar
1 inch should be ok with some decent air movement.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Old 10-04-2010, 10:25 PM
I agree, that looks like enough space.
Good job on the A/C insulation.
The radiator cap should be OK too, it dosen't
get that hot anyway. Probably around 150-160
degrees max.
Looks good....
How close should I place my mufflers? Mrwilson Engine 3 05-17-2007 06:03 AM
Coil mounted too close to the thermostat junkyardjeff Electrical 4 03-24-2007 08:37 AM
How to load a pic for my Icon GearHead69 Hotrodders' Lounge 2 07-18-2003 09:54 AM
Can you attach a pic in a thread chevyluvnpuppy Hotrodders Site Suggestions and Help 3 05-28-2003 12:42 PM
Pic of the 429 BigBlockBabe Hotrodders' Lounge 12 01-27-2003 09:19 PM
