How close to headers can muffler be? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-04-2010, 12:39 PM
The 383 stroker I'm putting the cherry bombs on will go on hedman headers. How close can they be?I'd like to be a foot from collector. Thoughts?
PS. I remember these things dumping their guts early in life way back when. Is it still the case and will being that close be worse?
Old 01-04-2010, 12:54 PM
Banned
closer will make them wear faster (its hotter), you'll have to tune it on a dyno to find optimal placement, I'd go about 2 feet, muffler, dumped to the side. Its cheap and easy.
Some mufflers are inside the headers...
Old 01-04-2010, 03:33 PM
close heats floor board and trans heats up from it .
i'd put on turbo's and get more power and less noise and put past tranny .
Old 01-04-2010, 04:33 PM
Less noise, Wheres the fun in that? This babies gonna bark. I thought cherry's were king of flow,aka power?
Old 01-04-2010, 04:44 PM
C-boStyle™'s Avatar
Rev2Red
When i was a lot younger and asked a lot of questions (maybe 13 years old).. I was told by a guy that built hot rods that if you take a crayon and mark your exhaust pipes from the collectors as far back as you can, then start the engine for a few min, shut the engine back off, then check to see how far back the crayon melted, the crayon mark would let you know where you should place you mufflers..
I dont know if this is true or not..
Old 01-04-2010, 04:48 PM
less power , no back pressure .
i ran glass till a man offered his turbo's for free to see the difference .
i even ran straight header , even more loss
he was right , but it may be type motor build .
also noticed i could hear better .
Old 01-04-2010, 04:55 PM
Wiki Edits: 31
cherry bombs actully increase exhaust turbulance because of the way the fiberglass is courogated.. thrush magnum glasspacks are diffrent using the perforated tube which works much better
Old 01-04-2010, 05:51 PM
diamond mike's Avatar
throw me under the bus agian
i second, i put packs from the rear of headers, and yes it was loud. but like??muffled loud? ( not the best sound ) also, my 350 did seem to lose some power, maybe they were so loud the sound just didnt match the power? dont get me wrong, i LOVE loud cars, but glass packs to me, got kinda a dirty sound. i couldnt even hear my headers
Old 01-04-2010, 06:28 PM
C-boStyle™'s Avatar
Rev2Red
I'd say the worst exhaust sound from a v8 would be a v8 pickup with glasspacks and big chrome echo tips out the back!
The best bang for the buck would probably be Dynomax turbos..
Old 01-04-2010, 06:34 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Here are some flow numbers
http://www.broaderperformance.com/mu...flow_tests.htm
http://ls1tech.com/forums/ls1-domest.../t-119518.html
http://www.mustang50magazine.com/tec...son/index.html
http://customexhaustsounds.com/ (sound)
Google "muffler flow comparison" or "Muffler Sound Comparison" to hear them.
Luv the smell of NITRO in the morning.
Old 01-04-2010, 07:22 PM
Banned
funny how the age of information means the spread of BAD information
Old 01-04-2010, 08:05 PM
83SILVRADO's Avatar
GROUND POUNDER
just slap em on, hell i've had a pair of glasspacks mounted right up to my headers. Makes for a very loud exhaust. I was setting car alarms off as i idled down the street. And i love the smell of burnin fiberglass!!!
What has been your experience with headers compaired to stock exhaust manifolds?? Jim Weeks Engine 10 10-06-2012 11:21 AM
making custom headers??? aztek_warrior Engine 2 07-11-2006 10:13 PM
Repair holes in .. headers ??? vorgath Engine 7 01-08-2006 09:55 AM
tri y headers or standard full tube headers fordracing Engine 10 06-13-2003 06:39 AM
Ford Block hugger headers Pilot34Coupe Engine 1 02-25-2003 05:18 PM
