How cold is too cold for filler? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-22-2007, 07:36 PM
I am newbie taking on learning body work, I have been a mechanic for 25 years but really want to learn "the other side" so to speak. I have a new shop with overhead heating that warms things up pretty well, however we have been having lows into the single digits so it takes forever to heat things up into the the 50-60 degree range, then the heater runs non-stop trying to maintain a decent temp. I am trying to figure out if it makes sense for me to start applying filler while it is so cold, do I want to pay the heating bills to leave the heater blowing away between coats, etc? My project is fabbed and ready but I am not sure it would be wise to tackle right now or wait until it warms up in a few weeks? Cold weather guys help me out here..
Old 01-22-2007, 07:51 PM
Here, read this http://www.autobody101.com/forums/viewtopic.php?t=7494
It should answer your questions.
BTW - I never apply fillers or primers below 65F. Filler I would not go below 60F
Ed
Old 01-22-2007, 08:30 PM
Use a heat lamp or similar to warm the repair area up before the filler is applied and also during the curing stage, you can sand it at any temperature. Shoot for a minimum of 60 degree panel temperature, 65-70 would be better.
Old 01-23-2007, 07:17 AM
crashtech's Avatar
Technician
Last wiki edit: Epoxy primer
Wiki Edits: 17
Some sort of heat lamp and an infrared thermometer are very important tools for paint & body during the winter. Minimum metal temps of 60 are a good rule of thumb for most activities.
Why a Cold Engine Runs Poorly leejoy Engine 10 04-10-2006 11:29 AM
cold weather engine screeching montea General Rodding Tech 11 01-30-2006 02:25 PM
Cold natured!! Does it have to be? dpjmw Engine 6 03-23-2005 07:29 PM
Too long of a cold idle woundup Introduce Yourself 1 11-24-2004 04:42 PM
How cold is too cold to paint in a makeshift booth? misteryu Body - Exterior 8 11-08-2004 05:56 PM
