how to connect wiring to sending unit - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2006, 12:28 PM
zipfactor's Avatar
Last journal entry: Just starting
Hey all,
I know this is kind of a stupid question but, how do you connect the temperature sending unit wire to the temperature sending unit? I have a 350 chevy motor and i never had the connector. The sending unit has the button terminal on it, for use with a gauge. Thanks all
Old 05-11-2006, 03:38 PM
docvette's Avatar
Wiki Edits: 12
Originally Posted by zipfactor
Hey all,
Doc here,
ZIPFACTOR:
No such thing as a "Stupid Question" ... except for the one that comes out.."Now how did I manage to do this?"
The Temp Sender is simple..For GM SBC's It comes in two Flavors..
one has a Rubber Plug on top of the sender and two blade ~like Connectors on it..Later model type with (usually a temp reporting wire for the ECU) This is not what you described..
The other is a Single terminal unit that screws into the head or water neck or manifold , and uses the sender Body as a ground. The Top single terminal is "Rounded" and accepts a "Slide terminal" Just hook your sender wire to there, and your good to go!
If you don't have the terminal, or lost the stock clip, or it burned up and fell apart under heat, you can use a regular Slide Terminal from a crimp kit..Blue usually works, but red may be needed for a tighter fit.
The senders work Based on Resistance to ground from the gauge to sender...Depending on the system , as it gets hotter the sender heats a bimetallic strip that changes the resistance to the gauge..Ergo, the gauge go high or low..as it cools the strip changes direction and the gauge follows suit.
The important thing to remember here is , is the gauge matched to the resistance of the sender? If it's all stock , then your fine, If you have aftermarket Gauges, you may have to match the sender to the Q of the gauge circuit..
They come in 0 to 30, 0 to 60, 0 to 90..all the way up to 0 to 290 Ohms resistance..the gauge must match the resistance of the sender to be accurate or work at all..Check your instructions if aftermarket.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 05-12-2006, 11:34 AM
zipfactor's Avatar
thanks doc, appreciate the help as always!
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
aod speedo sending unit ? 56f100 Transmission - Rearend 2 09-30-2005 06:23 AM
Fuel Sending Unit Wiring For Fuel Cells nightrain_rod Electrical 6 01-03-2004 08:24 AM
tbi 350 oil pressure sending unit problem HELP orangebaja Engine 3 11-07-2003 07:23 PM
Where can I install my water temp sending unit? CHEV66JB Engine 1 05-11-2003 06:15 PM
