how to convert a rearend - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-10-2005, 02:52 PM
i was wondering how i could make my limted slip rear-end a pose track rear-end without welding my spider gears together??
Old 05-10-2005, 03:25 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Limited slip is a posi-track. Just different names for the same thing. If you want to lock the rear, you can get a mini-spool that replaces the spider gears - a sleeve with splined holes on both ends that the axles slip into.
These are all over ebaY all the time and go for less than $20 for Ford Hotchkiss 9".
These Dana type spools (Chevy, Jeep, etc.) are on ebaY too but not as many and cost ~$60.
Old 05-10-2005, 03:33 PM
Wiki Edits: 49
It should be noted that mini spools are for racing only and are definitely NOT recommended for street use. They can be very dangerous on the street, not to mention having to buy rear tires every two weeks since they don't go around corners very well.
57 chevy REAREND dillema AND1TOO Transmission - Rearend 1 05-04-2003 12:16 AM
rearend for a Model A 30coupe Transmission - Rearend 10 11-25-2002 09:04 PM
measurments for a rearend 50chevyfastback Transmission - Rearend 2 10-04-2002 01:19 PM
Ford Rearend 00stang Transmission - Rearend 5 08-25-2002 05:12 AM
