How to cover dashboard - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-13-2011, 06:03 PM
I built a custom dashboard for my 1980 el camino out of an el camino dashboard and a 1980 camaro dashboard, and between them i sprayed in spray foam and bolted the dashboards together then used a layer of fiberglass on top between them to help make it rigid.
Now i have put a 1/4 inch foam pad on top of the dash and sawed all of the spray foam flat on the dashboard and i'm wondering how i can go about covering it. i have 3 yards of 54 inch wide vinyl and i don't know whether i should glue it on and cover the seams or have my friend attempt to sew me a cover that slips on like a cover for a seat.
or would there be an easier way to cover it in vinyl? any suggestions would help
Old 01-14-2011, 12:07 AM
DanTwoLakes's Avatar
Wiki Edits: 22
If the dash doesn't have a lot of sharp angles or deep places then it would be better to glue the vinyl on with HHR (high heat resistant) top and trim contact adhesive, like DAP or 3-M. You won't find this glue at a home center, you need to get it at an upholstery supply place or from an upholsterer.
Old 01-14-2011, 09:15 AM
Hey Dan, Not to change the subject but where do you usually get your HH66 adhesive from? Also do you know who carries "Barges" rubber cement?
Thanks a lot!
Hey Recepswilliams, how bout some photos of that dash you created.
Bryan
Last edited by DanTwoLakes; 01-14-2011 at 09:40 AM. Reason: Violation of guidelines. Please see: general board guidelines.
Old 01-14-2011, 09:41 AM
Wiki Edits: 22
I don't use either one, but here's where to get the HH-66: CLICK HERE As far as Barge Rubber Cement, it's available all over the internet.
56 Chevy dashboard I_3putt Interior 2 03-26-2007 06:48 PM
Dashboard mosstrooper Hotrodders' Lounge 0 12-08-2006 12:29 PM
MDF Dashboard frame akattp Interior 17 11-09-2004 02:22 PM
need new dashboard bigred#4 Interior 1 04-25-2003 05:17 AM
Dashboard 49 Lincoln WardellW Hotrodders' Lounge 4 04-13-2002 02:21 PM
